the O2 socket has a gap you can slide the wire out of i have one, best investment ever when i need to remove it... But go to your local parts store
its like 20 bucks for hte socket
I see, thought it was one of those $100 tools which you use once every 2-3 years! Will check the local Repco and get a O2 sensor from them too. One size fits all?
thanks for the tip .. I was really not keen on removing that heat sheilding to get a spanner in there.
yeha
but unless you cut off the lead fmor your OLD o2 sensor you cant use a socket
other option is to take off your o2huosing and then remove with a wrench.
ther eare two sizes that i know of
i got the larger one
it has worked on everything from Mecedes, to hondas, to mitsu, to nissan
Thats exactly the economy my series 2 gets. I earthed the boost solenoid last week, so am interested in how that affects economy. I have a theory (untested) that having higher boost coming on early will assist in moving the weight of the Stag up to cruising speeds easier, so therefore the fuel consumption my even out, or even be slightly better. I will let you know how it goes. It certainly helps the driveability, and means I dont have to sink the right foot as hard as before.
I havent done a trip in the car since getting it a year ago. I was hoping to come up for the skyline show & shine, but had to miss that in favour of the rugby test.
Brief Update. Fuel economy the same as before (420kms). This is good news, given the improvements in mid-range power and torque. Not sure whether one trip is enough evidence to test my theory, but it certainly hasnt gone backwards. :(
lol not me a mate dreamed it up (should open a tool store i reckon), but it does work pretty well, since we cut it down short enough to be able to turn it more easily down on the rear dump pipe which is really tight. Pretty sure it was 22mm which was the other bonus.....who is going to miss a 22mm ring spanner?
try your local autoparts supplier other than the ones mentioned above, i mean small ones they might have it or they will be able to source one for you.
Tried spanner, couldn't get enough "purchase" to twist.
I've ordered a socket from ebay, $22.80 delivered. Hopefully I'll get it next week. Once I have it, anyone in Adelaide need to borrow it, PM me :P
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
