  • Replies 199
Posted Images
looks like a top event. sorry I had to quietly opt out and didn't make it down.
Instead I stayed in nsw, got work done on friday, then brisbied my car at eastern creek on sunday :) looks like I would have been better off at deca.
Dude this sounds bad what happened????
basically
poor set-up rear end (was trying new set-up, but 8kg springs + 28mm sway bar = no rear end grip).
poor driver
snap oversteer
concrete wall
basically
poor driver
snap oversteer
concrete wall
Ouch dude.... least it wasn't tooo bad!!! Kisses u can handle hits hurt!!!
I missed this before.....
Heh thanks to the late night crew as well, was good fun!
Im not sure if Id call it a late night, or an early morning!!
But agree - was fun.
Oh yeah.... and next time, im taking your credit cards too :) - your just as bad (if not worse) than the Bris.
rest of the vids have finally finished uploading:
http://decamay07.racemeets.net/
so basically if u hit the skid pan in either of the morning sessions you should be there
cheers
thanks for the great vids. nice work
cheers
Thanks heaps for posting the vids mate, they are great to watch. I liked the zoomed in take off shot on one of my runs :D
Cheers
Ben
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
