As per the topic, can the hicas computer that is mounted underneath the parcel tray in the boot be removed after you remove the hicas system.
Likewise can you remove the computer that is basically identical but on the passenger side of the vehicle, i suspect this computer is the for the abs. Like the hicas computer it is mounted underneath the parcel tray but is on the passenger side of the vehicle, where as what i suspect to be the hicas computer is on the drivers side.
This leads me to wonder if removing these computers will "open" any circuits in the car causing things to function incorrectly. Im also not sure if skylines have speed sensitive steering in any way, ie making the wheel easier to turn at different speeds etc and exaclty what the ecu is using the speed signal for etc.
heres a pic of the two computers im talking about
Any thoughts would be much appreciated.
Edited by 2630GTS
https://www.sau.com.au/forums/topic/169399-removing-the-hicas-computer/
Sorry to steal the thread,
But is there any special sensor (inertia?) inside the hicas box under the parcel shelf, which means you cant relocate the control box? I want to move mine so its not in the way of my audio gear - but someone said there might be a sensor inside which needs to be level, in the center of the car.
Thought: Nissan generally didn't put stuff in the car for no reason.
The module on the passenger side is the ATTESSA computer - so by all means if you are tired of AWD then bin it.
The other computer is the HICAS unit. If you want to remove its function the easiest way to do it is get a Tomei HICAS canceller or a bar that replaces the steering rack. Don't remove the computer if your rear steering rack is still active otherwise you will be on your way to the mother of all accidents......
Thought: god gave u eyes for a reason, And if u used them u would notice i have a HCR32, not a gtr/gts4
I ask this because i have removed the hicas system was wondering since its gone if the computer could go to.
The unit on the passenger side i have since found out is the abs unit, and since im considering removing the abs thought it would be a good time to ask about that also.
thanks for the 2 cents worth tho
I moved mine for the same reason. I didnt have any problem so id say there is a 99% chance u will be fine. Maybe ask some of the guys in the car audio section.
The hicas computer is still inline with the speed sensitive steering. If you can figure out a way to maintain the speed signal to the steering when removing the unit it should work.
I have been wondering whether you can just splice the speedo signal wire at the ecu into the solenoid but i'm not game to try and don't have the knowledge to be certain if it would work or blow something up anyway.
I'm pretty sure there's another thread on this topic where they got into the nitty gritty of the signal required and all sorts of shit and it sounded to me like it was just the square wave speed signal which the speed sensor on the back of the speedo puts out.
BHDave: totally wrong type of signal you have there. Frequency modulated fixed duty waveform input as speed reference signal, pulse width modulated fixed frequency output to solenoid.
James. (I'm maybe looking at learning to program PIC's to make up a small converter to do this though.. If I find the time and motivation)
I just ripped my HICAS computer out, the power steering still works, just on the highway mode. It's not that heavy.
But after I dopped my engine out, I didn't hook the power steering wires up properly, so it was stuck in highway mode anyway.
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
    • Are you guys meeting up with the Sydney SAU guys at Lambton Pool Carpark or heading straight in?
