hey i have a r32 approx 260rwkw using for hillclimb/sprints and bit of track im thinking of running r33gtr 324mm rotors with caliper spacers, A1RM pads on the front matched with dba4000 slotted rotors and penrite sin race brake fluid the question is what is a good combo for the rear? do i require slotted rotors along with another set of A1RM pads or would hpx's do the job?
cheers
Edited by freestyleMX
I posted that in june 2009 - after I had given up on the A1RM's - don't buy them if you can't stand extreme noise! - and had swapped to the bendix heavy duty. A week or so ago they wore out, so I got almost 3 years of driving around town with them on which isn't any where near as good as the original ones.
Needed another pad in a hurry, so put the a1m in that where sitting in the shelf. Lasted in 3 days as I'd forgotten how bad they were for noise! I even tried the anti noise spray etc etc, before giving up on them yet again...
While I was down at repco buying something else, I mentioned I was looking at some new pads and the guy said they do repco branded ones for the skyline now, which are super quite with integrated shims. Given I was buying a few other things he did them for $70 (for the front two pairs) so I thought, what the heck, worth trying.
I've been pleasantly surprised - dead quite, reasonably good feel - but remember I'm not doing track (or anything like it!) I'm just driving around town... If you want a straight replacement when the standard ones where out, I don't think it is a bad choice...
Ian
ps PM me if you want a pair of not very used front A1RM's for a r34 gtt for a cheap price, as they are never going in again... :-)
I would strongly disagree about the pad noise. I have been driving with A1RMs on the front brakes with my s14 for about 10months. I drive at least 3 times per week, if not daily. I only experience braking squeal rarely when pulling up. Overall, brake squeal isn't as issue with this pad. I will conceed pad dust is a major factor but probably a lot more noticable on white rims. Cold performance is hard to tell since my tyres also have trouble in the cold, so cant really tell. though i suspect having both susceptible to the cold doesn't help.
Unfortunately HPXs don't last on the track, even on the rears. I thought I could get away with them but after two days at Phillip Isand and 3 months of semi-regular daily driving, they are already gone.
Will be switching back to the A1RMs when I have the time to change them. ( Still using A1RMs on the front. )
just tried a set of QFM A1RMs in my r32 gtr for a club day on the weekend, they weren't at all noisy and worked well but they are around 2/3 worn out after just one day? i would of liked to get a couple of days out of a set of pads or am i asking too much?
Pads start wearing that quickly when they get too hot. Use a higher heat rated pad and you will get a few track days out of one set.
I have been using Hawk DTC-60 on front of my GTS-T and HT-10 on the rear for a while now. They wear slowly, never really fade and work from cold but they are designed as a track only pad.. really bad dust, noise etc. You can get them cheap from http://www.hawkpadsdirect.com/ so for the money i think they are hard to beat. Only thing is they are super super aggressive so take some getting used to. Personally I would suggest a pad thats easier to modulate (they will generally say something like "less initial bite") esp if you arent used to really high friction pads.
If you dont mind spending more $$ then some of the project mu or endless track only pads would be my first choice.
dont rule out the QFM comp pads, ie Comp 9 and comp 2 etc. A1RM's on a GTR at symmons is a fairly big ask, especially if its standard weight with standed size rotors etc.
Has anyone tried the new Ferodo DS Uno pads on track? I had them recommended by one of the larger race brake suppliers in the country, and apparently everyone 'raves' about them.
Has anyone used them and are they worth raving about? Any feedback on durability, disc life, modulation, etc.?
Alternative is Pagid RS14 / RS29 for similar price.
Thanks
Jack
Edited by 4Pot
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
