I'm assuming you DO want more top end power than the stock turbo??
because you wont beat the stock turbo for response. :/
other options like a highflow rb25 turbo (ie. GCG) might be the way to go, steel wheels etc. and similar response to stock...
but in short, Nissan lightened the stock turbo by using plastic/nylon and ceramic components. It means it wont last as long and cant take much boost (1 bar is enough to kill it very quickly) but if the car is left stock and not thrashed it would probably suit it just fine.
If you want more power than the stock turbo can give you, there will likely be some compromises and one of those will be slightly less response/more lag.
You can still keep turbo lag pretty close to stock however...just not exactly the same ;)
gcg is garret is it not? correct me if im wrong thats just what i thougth it was. but dnt for get slideingperformance on these forums he does highflows for like 1200ish i think.
garrett an gcg are to different companies,garrett does there hi-flow for about $2200,gcg does there's for about $1700,garrett has a lot better/stronger components in side there turbo,i did a little custom work for garrett in december,
HKS GT2530 for the win. :ermm: Blistering response, I think it would be just the same as stock turbo if not better. But it does run out of air up top, I think from research it dies from ~-5500rpm, but that saves you having to go to redline all the time.
Just for an opinion, I just installed a GT-RS and running on just the HKS actuator I can't tell a difference between the stock turbo with tuned EBC and the GTRS in terms of lag.
So what is actually stronger? Because to me that sounds like a pretty incorrect statement
The GCG uses:
Garrett cartridge
Garrett wheels
Factory machined housings
The Garrett item uses
Garrett cartridge
Garrett wheels
So what parts are actually left that are different? None.
That to me suggests they are (component wise) the same thing.
Ignoring the actual spec of the turbos which is irrelevant when we talk strength of components.
The TD05 is a bitch to fit, but for what its worth - its a fair bit better than the stock R33 turbo.
A mate of mine runs a TD05 16G from an EVO 3 on his RB20DET. It DOESN'T spin the "wrong" way, has a single pulse turbine housing, spools about the same on the RB20 as R33 turbos spool on RB20s - but flows an absolute crapload better up high. It hit ~200rwkw without trying too hard....
They run a much larger turbine wheel than R33 turbos, and a slightly bigger compressor wheel - I'd say they'd have to be easily comparable with an HKS GT2530 in terms of power and spool.
It should be the same as a GT2835 with the .48 A/R in terms of power if it's from an EVO 3
  • 2 years later...
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
