I'm assuming you DO want more top end power than the stock turbo??
because you wont beat the stock turbo for response. :/
other options like a highflow rb25 turbo (ie. GCG) might be the way to go, steel wheels etc. and similar response to stock...
but in short, Nissan lightened the stock turbo by using plastic/nylon and ceramic components. It means it wont last as long and cant take much boost (1 bar is enough to kill it very quickly) but if the car is left stock and not thrashed it would probably suit it just fine.
If you want more power than the stock turbo can give you, there will likely be some compromises and one of those will be slightly less response/more lag.
You can still keep turbo lag pretty close to stock however...just not exactly the same ;)
gcg is garret is it not? correct me if im wrong thats just what i thougth it was. but dnt for get slideingperformance on these forums he does highflows for like 1200ish i think.
garrett an gcg are to different companies,garrett does there hi-flow for about $2200,gcg does there's for about $1700,garrett has a lot better/stronger components in side there turbo,i did a little custom work for garrett in december,
HKS GT2530 for the win. :ermm: Blistering response, I think it would be just the same as stock turbo if not better. But it does run out of air up top, I think from research it dies from ~-5500rpm, but that saves you having to go to redline all the time.
Just for an opinion, I just installed a GT-RS and running on just the HKS actuator I can't tell a difference between the stock turbo with tuned EBC and the GTRS in terms of lag.
So what is actually stronger? Because to me that sounds like a pretty incorrect statement
The GCG uses:
Garrett cartridge
Garrett wheels
Factory machined housings
The Garrett item uses
Garrett cartridge
Garrett wheels
So what parts are actually left that are different? None.
That to me suggests they are (component wise) the same thing.
Ignoring the actual spec of the turbos which is irrelevant when we talk strength of components.
The TD05 is a bitch to fit, but for what its worth - its a fair bit better than the stock R33 turbo.
A mate of mine runs a TD05 16G from an EVO 3 on his RB20DET. It DOESN'T spin the "wrong" way, has a single pulse turbine housing, spools about the same on the RB20 as R33 turbos spool on RB20s - but flows an absolute crapload better up high. It hit ~200rwkw without trying too hard....
They run a much larger turbine wheel than R33 turbos, and a slightly bigger compressor wheel - I'd say they'd have to be easily comparable with an HKS GT2530 in terms of power and spool.
It should be the same as a GT2835 with the .48 A/R in terms of power if it's from an EVO 3
  • 2 years later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
