Gear Knob Warmer
Hand made hat for your gear knob. Available in a range of colours to match your Mini. Pictured is my Electric Blue/EB one, along with a Chilli Red/White one. These are made to order just state in the notes box what colours you want. (p.s. please don't try driving with the warmer in place)
From a Mini Car website lol
i also have a razo gearing knob
it burns like a bitch in summer, cant stand it need a leather one when summer comes
but atm its only cold, all u have to do is rub it a bit(yes rub ur knob) and i dun really see it as a problem
razo gearing knobs are crap, wouldnt get another one even if it 'looks' good
You're forgetting the worst part - metal gear knobs in summer!
I had a Nismo titanium one in the GT-R and remember getting into the car after it had been parked for a few hours in the sun.
I touched the shifter and swear it nearly burned NISMO into my hand.
I felt like this guy...
Gear Knob Warmer
how is it going to warm your gear knob? what do they think, the knob has heat or it's own to keep in. some stupid knob design that it :)
hey tekin
i have the same knob i think. just a flush silver razo one
it gets pretty cold in winter, not much u can do. but summer is by far the worst. i struggle to change gears if its in the sun for a few hours
Rekin....nice one...best answer so far' but useless as Kyle stated...but looked good to warm the real knob...
Joshua...If I hardened the f#$k up anymore...I would be a 2 day old stiff..
Shaun...hair drier...how would I explain that to my friends when I have no hair
James....do evos./hummers come with nismo c/f knobs...
Steven...a few more days and I am fitting the original back on..
Paul...I would suggest we both melt them down and make a razo....battery operated shinny thing-ama-jig that looks like a bullet.
Oh...Ash.....some don't have one...so it does not shrink...LOL
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
