I'm just about to do my first service on my R32 GTST since it arrived from japan.
The only engine mods it has is a full apexi exhaust.
It still has the factory airbox with a nonbrand name filter inside.
As an apexi filter to go within the factory box is around $80,
i thought i may as well buy an Apexi Pod filter that bolts directly onto the AFM for an extra twenty bucks.
The car has factory computer i dont think its had any tuning done.
It runs superb, so I didnt want to f**k anything up by adding the pod filter.
I'm just asking for peoples thoughts comments or suggestions.
Wether Its better i stick to the factory air box, or chuck this pod filter on?
And if any tuning needs to be done once the pod filter is on there?
Cheers
exhaust + filter are very minor mods, I think a remap would be an expensive way to gain a couple of kw.
box the pod if you want good performance, otherwise you'll suck in hot air. otherwise stick to the airbox.
the stock ecu can't be tuned without remapping it. if you take it to any random workshop with a dyno and ask them to tune it, there is about a 90% chance all they will do is a power run, and just have a look at the afr's. they probably won't even pop the bonnet.
Hmmm, my R32 GTSt was stock when I got it, I added a dump pipe back 3" exhaust and it went really well. I added a K&N pod with heat shied and it started hesitating when the car came on boost, like I was hitting a fuel/boost cut or something? I've since changed it back to the stok airbox and reset the ECU and it goes better than with the pod.
any tips when making an airbox to fit around the apexi pod?
Materials , dimensions, or anything to take note of?
Cheers
This is what i made up in 1 afternoon
Bellmouth attached to a 3" 90 degree bend
Half round heat sheild and bracket from super cheap
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
