  • Replies 191
DIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIISH!
So much so, you could roll out your sleeping bag, set up a little night side table and move into there when the missus kicks you out!
thats not dish
THIS is dish
has the face been wleded around the wrong way?
who ever puts that on their car needs a a massive the sphincter of the universe slap from a massive black man!
Edited by GTS4WD
I have seen these in the flesh at Ernie's Skyline Imports in Brisbane. They are called 'COO' and they look as good as the photos.
They are brand new and awaiting compliance. I think they would make an awesome runabout for the wife and kids without looking like a complete idiot driving a Smart Car.
Serious?
If so l'll prolly sell the stagea if you can start importing them in. Size wise they're perfect for what l need a car for, and just lowered with bigger wheels they look HOT!!!
I've wanted for quiet a while either a Scion or a Honda Element.
Something like this would do the job! :D
http://www.autoblog.com/media/2006/04/Elem...3-4-closeup.jpg
Edited by -FUZZY-
Serious?
Something like this would do the job! :)
why would you ever want a honda?????? :)
  • 1 month later...
  • 1 month later...
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
