received an email from a mate, thought Id share:
The patent holder of "the clear wheel" and a company called Forgiato are now making clear mag wheels (20in or 22in only) with glass-like finish hard coated 50mm thick polycarbonate centre. The centre is 1.5 or 2" polycarbonate, chemical hard coated both sides.
Weight for the 20" mag is 27 lbs, and the 22" mag is 38 lbs (complete wheel weight)
All other parts of the wheel are forged 6061t aluminium (Inner and outer hoops and Hub centre)
SAE tested, certified and passed Impact, cornering and radial tests.
RRP is $5000.00 per wheel
$5grand USD each. $20g usd a set of 4, say 30grand AUD once imported with taxes paid? Anyway, Id say give it 5 yrs and they'd be affordable, I guess a bit like a plasma tv which where in the tens of thousands when new to the market, or like a dvd player which used to retail at 2 grand - now they have come down over time to 50bucks.
flame me if its a repost, but meh I thought Id share......
https://www.sau.com.au/forums/topic/172471-clear-wheels/
looks weird as, as said before would look shit on a car with stock brakes hahahahaha
rice them up with some neons behind or something.. now that would be trippy....
dont mind them too much i guess something new.... next they will be cutting spokes in them!
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3175044
very old, very tacky
just like spinners i can only see these stupid things taking off in the usa.....or japan.
a few years ago at the sema show they had clear rims that had L.E.D's in them and when the wheel spun it created a customized message. it looked pretty trippy but still so tacky
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3175764
Can you remove the glass or something? Cuz brake dust gonna coat the inside of the glass and you can't clean it?
i know im just covering minor details here, but it isnt glass, its polycarbonate, there is a difference.
and i sincerely doubt theyre meant for show purposes only, not the street.
theyre not practical, they'd be heavy, a 20"x2" plate of polycarb is not light by any stretch of the imagination.
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3177742
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
