received an email from a mate, thought Id share:
The patent holder of "the clear wheel" and a company called Forgiato are now making clear mag wheels (20in or 22in only) with glass-like finish hard coated 50mm thick polycarbonate centre. The centre is 1.5 or 2" polycarbonate, chemical hard coated both sides.
Weight for the 20" mag is 27 lbs, and the 22" mag is 38 lbs (complete wheel weight)
All other parts of the wheel are forged 6061t aluminium (Inner and outer hoops and Hub centre)
SAE tested, certified and passed Impact, cornering and radial tests.
RRP is $5000.00 per wheel
$5grand USD each. $20g usd a set of 4, say 30grand AUD once imported with taxes paid? Anyway, Id say give it 5 yrs and they'd be affordable, I guess a bit like a plasma tv which where in the tens of thousands when new to the market, or like a dvd player which used to retail at 2 grand - now they have come down over time to 50bucks.
flame me if its a repost, but meh I thought Id share......
https://www.sau.com.au/forums/topic/172471-clear-wheels/
looks weird as, as said before would look shit on a car with stock brakes hahahahaha
rice them up with some neons behind or something.. now that would be trippy....
dont mind them too much i guess something new.... next they will be cutting spokes in them!
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3175044
very old, very tacky
just like spinners i can only see these stupid things taking off in the usa.....or japan.
a few years ago at the sema show they had clear rims that had L.E.D's in them and when the wheel spun it created a customized message. it looked pretty trippy but still so tacky
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3175764
Can you remove the glass or something? Cuz brake dust gonna coat the inside of the glass and you can't clean it?
i know im just covering minor details here, but it isnt glass, its polycarbonate, there is a difference.
and i sincerely doubt theyre meant for show purposes only, not the street.
theyre not practical, they'd be heavy, a 20"x2" plate of polycarb is not light by any stretch of the imagination.
https://www.sau.com.au/forums/topic/172471-clear-wheels/#findComment-3177742
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
    • I had the fuel rail out to check the injectors before getting the ECU reprogrammed. The guy said that the injectors were fine, but the regulator was cactus (leaking fuel out the vac port, randomly changing pressure. I decided to replace the FPR with an adjustable unit. I have purchased 2 now, and neither has an appropriate adapter to fit where the FPR mounts. I need advice on where I can get an adjustable FPR that will simply drop in on a RB25DET. TIA
