Hey just me again,
Thanks once again for the part no's you were able to get for me last week they were tops and i ordered and fitted the parts from Nissan on the weekend!
Just another quick question for the Injector Sealing O-rings are they the same part on the r33 gtr as on the r32 gtr, (16636-V5000) or another no altogether, and are they the seal between the fuel rail and the injector head? As that's the part i'm after!
Many Thanks once again,
All your help here with Part #'s is excellent!
skysaresilver
The o-ring seals on the injectors are all the same. The bigger seals at the top of the injector head where they fit into the fuel rail don't actually seal anything. They are there to act more or less like a shock absorber. The only seals to worry about are the o-rings.
That was actually going to be my next quesiton.
After looking in the workshop manual they say to change the insulators as well as the o-ring.
Do you have the insulator number as well?
Seeing as I am changing them to try and track down a running issue, I figure I might as well change all.
Thanks.
David
Oh and can you give me the part number for the coolant temp sensor (looks like the air temp sensor in the plenum).
Can can you verify if they are the same sensor for both coolant temp and air temp?
Thanks.
D.
Thanks Ron, I really appreciate it. :action-smiley-069:
Do you know if the coolant temp sensor is the same part number as the air temp sensor in the plenum?
Thanks.
If you ever come to the Bahamas, I will definitly by you a pint. :P
D.
I searched for the air temp sensor but only found air bag sensors. Mind you i was stuffed last night. I'm thinking it could be an exhaust temp sensor (even though its located before the exhaust) the program can be funny like that I reckon.
Can anybody that know's which part we are looking for help out?
Hey all, and i big hello to AREP3
I apologise for my disappearance from the forums. I no longer have the time to commit to posting part numbers on the board, but i will do what I can, so what i would suggest is do a search on the forum for what you are after as they will be scattered throughout the place.
Ill be back here and there.
AREP3, your doing a marvelous job here! if only i could nominate you for a logie.
kind regards,
Arbess
Thanks Ron, I really appreciate it. :P
Thanks.
If you ever come to the Bahamas, I will definitly by you a pint. :)
D.
Had another look mate and all I can get is the same part number so i'm GUESSING that they are the same part.
Hey I have a double request:
R33 Gtst - inlet cam gear with VCT 13024-42L02-
R34 Gtst (NEO) - inlet cam gear with VCT13024-5L300-
Want to see if they're the same.....fingers crossed.
Not the same sorry mate
Can i also enquire about:
R32 gstst - inlet cam gear with VCT
Cheers
Dane
Hi there
I want to know the part number of the two arms that hold up the boot lip for a R34 GTT 4DR...and also will i be able to order a repair manual from nissan for my car...Thanks
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
