  • Replies 54
Reminds me of an old song "I don't like Mondays, I'm gonna shoooot shooot-oooo-oooo-ooo-ooot, the whole day down"
Yeah bad news RIP to the victim :whistling: Very scary story, makes you think twice about helping people in distress huh. Worst bit it I would have done the same, ran to help!
Must be the time of year for it..
When I saw the story title I thought maybe it had been on our street!
Last night the cop chopper was flying around for ages shining their light up and down the street and then 10mins later 2 ambulances went flying past. :\
The chopper flies above the house all the time.. and this is a quiet street..
Around the corner from me... and im here in lockdown.
Cant leave the bloody office.
SIF the gunman is still gonig to be anywhere near this place.
Mate here @ work who sits next to me, his mate saw the whole thing right infront of him on his way to a job interview...
Certainly not a good start to the day.
The man is described as being 192cms tall
192cm? wonder who gave that description
"She was powerless. A couple of guys came to assist … he pulled out a gun."
"He shot one of the guys twice. Then he shot the woman and then the other guy."
what gets me is how some1 thinks he is better then another and can do as he pleases, prick shot 3 people as if they were nothing
its said the girl was a stripper at spearmint rhino, and was doing a half naked/full naked dance for the boss at the bar. The shooter tried to drag her out, but was stopped by one of hte other patrons at the bar. Then later he tried to get her form a taxi or something (theage.com.au)
bad way to start the week :D
RIP to the deceased.
mental retardation prevents people such as this gunman from being rational....thats what happend with the v-tech shootings too...the gunman got it in his head that people were against him..
Apparently the alleged gunman was last seen on St Kilda Road.
Took nearly an hour to get from Lonsdale and Russell to Crown this morning. Walking to the office was kinda scary with cops in flak jackets and helicopters flying around. The news on the radio was pretty vague at 0830 and 0900 saying that there was an area cordened off in the city due to an "accident".
This was no bloody accident.
I had to drive through it this morning...was wondering why cop cars were appearing out of nowhere. I was just before William St when they blocked off the road. I didn't know what was going on until I heard it on the radio after I had already past through.
Very bad start to the week...and another reason why people will more reluctant to give a helping hand!!
RIP to the deceased just trying to help out.
Yeah its all over the news... interrupted the US Open this morning... rang a mate to make sure he was ok as it happened near my old work.
Its amazing how many different variations of what happened there are... i watched channel 10 and heard one thing... watched 9 and heard another and then read something different again in the age. No matter what version it is tho its a pretty shitty thing.
just watched the news - man that woman was pretty badly beat up...her left eye was swollen like a freakin basketball
apparently the guy is a very dangerous criminal (possibly still armed), and police are looking around the eastern side of vic
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
