Reading what Nick has said I don't think the lack of baffled sump is to blame.....however not over filling the car + the fact it doesn't have a baffled sump cannot be good. First and foremost Benno recommends that you over fill the car with oil...once thats taken care of any other mod like the baffles etc etc is extra insurance.
When you talk over fill. How much oil is going in a stock rb25 with no oil cooler ect.
  • Replies 60
Posted Images
Surely the clour of the oil isnt the best tell tale of oil condition. I would have thought that the level of detergeants in the oil also helps on that front. To me clean oil after 2000kms of abuse??? Makes me wonder where all the blow by, fuel contamination and carbon is going? If its not hitching a ride out of the engien with an oil change, not gettign held up in the filter...then its still in there.
no worries Al... was really just posting this to give some of the 25 guys a heads up...
Craig I think its 4.5L to fill her up...
Yeah Roy the oil was black as coal when I looked at it the Fri before I hit the track... but I thought... she'll be right lol
Group V oils are the bee's knees. Lots of moly and good HTHS sheer ratings. (this is an oil thread btw!)
Redline or Motul 300V are the brands of choice for any serious work. I do UOAs on my oil and Reldine has intresting results do to the addatives.
Black is not a bad thing, I would say it means ur oil is doing the right thing!
penrite and Castrol as mentioned are group IIIs. On top of that ur running a gp III with a wide visc spread...too many VIIs!
Mobile 1 at a minmum...but for u Nick redline all the way for ur track work, dunno why any1 would even consider running anything less than a Group V for these type of track cars, HTHS ratings are much better i.e. better under stress and load. U should see ur engine after a few cycles...it looks brand new and shiney.
Dont guess its condition...use good oil and do Use Oil Analysis (UOA) cost about $30 and will tell u exactly whats going on.
One of the main problems is the retention of oil in the back of the head on any of the RB series of engines. This is solved by running an oil line from the oil welsh plug in the back of the head down to the side of the sump on the drivers side.
The attached pictures show some good examples of this.
Sorry to hear about your engine.
Through the years, it is very seldom that I have heard of RB25s having bearing failure due to oil starvation, but i guess theres always exceptions. Putting a sump on it I would say is unecessary but a good oil cooler and pump helps.
As for the penrite stuff - I would throw it away rather than put it in my car.
For years in all my cars I have run the Castrol Sythetic R (aka Formula R) and havent had a problem. I have to admit the oil comes out pretty second rate on changes after 5000 kilometers, but neverthless hasnt given me any hassles.
The Motul and Redline Oils are both Extremely good, The Redline oil in particular is a must if your driving a highly stressed out engine, it is much more expensive, but if your using the car in competition, I would recommend it. Circuit driving is far more demanding that drift, in a way that you are driving the car at its limit most of the time doing several laps, where at a drift circuit you might do 1 pass and let it cool or do a handful of laps at the most.
Whether it be circuit or drifting, I beleive that if you compete you should adeqately set up your vehicle, not only for it to perform the best, but to preserve the engine and drivertrain.
For what its worth mate here is the setup I am installing in my build. Oil is everything to me.
Stage 3 Hi energy gated and baffled sump. chamfered and cleaned oil gallerys, Restrictors (I have converted the head to solid valvetrain) Jun oil pump. Bit pricey but based on research it is superior to the N1. HKS oil cooler. Bleed back from the head to the sump. My choice in oil has is redline but due to it being hard to obtain on an over the counter basis I have used and will continue to use motul .
Short of going to a dry sump setup I dont think there is much more I can do to give me as good an oiling system as I can get.
This is all very good and well...but lets not lose sight of the fact that there are plenty of ppl maign good power on std motors without all this oil control, blah, blah, blah and have been doing so reliably for quite some time. I dont doubt that my bottom end will let go, but its because im running the boost and revs i am...something has to give and it wont be becase i dont have a modified head, sump etc etc.
Overfill the sump a little, use good oil and you are away. I am the worlds biggest sceptic for all these super oils by Redline etc. Too many gearboxes go bang, and they seem to be good for ppl that want to run their oil for 50,000kms. Show me a race team with turbocharged cars using their oils, not a fleet of semis using it in their diesel truck engines that are red lined at 4,500rpm. But a race team that genuinely uses them.
I dont know, im just a little sceptical of the claims of the uber oil by small niche manufacturers. Perhaps the Motul woudl be aok, but not offered in the viscosity i like to run in a std Nissan engine that is makign 150% more power then std with std toerlances, cooling and oiling systems. I will take the extra viscosity for piece of mind :(
How about you define a budget if we wanna go down the "would you do it" route? :D
Because not everyone has the cash for everything. Whilst something maybe "nice" to have, it does not mean its a necessity by any means
I was very pleased when I was under my car for the first time to see that that plumbing from head to sump had been done.
I will take the extra viscosity for piece of mind :D
What do you mean by extra viscosity?
I am not talking about building you "dream machine" here, just a realistic rebuild budget; after all i am not a member of the Paker family :( .
I agree with your statement above. Is it a necessity; probably not (have stated that i swing on the side of caution).
Look at it this way: Alot of people think car insurance is not necessary (possibly due to finance issues), but what they don't consider is; what happens in that 1-in-1BIL chance they write off a Ferarri 430?
I would rather spend $700-$800 on a baffled sump to insure the life of a $10k+ assett. Which is not to say that something else could fail and damage the engine.
$700 for a better sump? I wish a decent sump was that cheap.
I realise we are not talking about dream machines. But if all the other oil issues are addressed. You run of the mill RWD car does not require a sump.
You wouldnt put a larger sump on there without doing the proper oil mods, and then once they are dont it fixes what would be the bandaid (the sump)
Proper oil mods.................. check (as per SK thread and also RB30 thread, most of which EAS knew about already)
Sump...............Check :D
Not too sure what quality you would consider the H.E. sump, but i think they're damn good and mine cost me about $800 for the circuit type. I just thought there would be cheaper options on the market
LOL... he really need to patent the term "Ben Spec" :P
I have a bunch of parts laying around which i want to make a motor out of. The main problem its all this added insurance that adds so much cost to the build that it hasnt been started. By the tme you have paid for a sump and and big dollar oil pump, then head mods (ok they are cheap), but where does it end. LOL...the longer my motor hangs together the more inclined i am to stick with std Nissan. Every 3-4years throw another $400-600 wrecker motor at it. Remember, Rule 671, R32 GTSt owners are TIGHT ASSESS !!!!!!!!!!!!!!! :closedeyes:
oil conversations going around based on some stuff some guy told u a while back or something u googled.
Dont guess, use facts. Do UOAs and work out what it means then do I few to see what it going on.
you spent 15k on an engine and then guess or skimp on ur your oil? lol People have been using Redline GEAR oil i.e. shockproof in thei GB...no suprise to me we read about them dying. Use a GB oil with the approipite friction modifiers, not a gear oil. If u change ur oil veer 2k then yeah no point use M1, Moly oils like redline need to go for some time to get the addatives to work.
Make sure u use a Group 4 or 5 oil. Not this 3 stuff like the castrol being mentioned.
As for extra viscosity...for a pure track car...no drama. Check the cSt ratings at 100 deg. W60s or similar have high numbers.
for street...use 40 as a max...its not about piece of mind its about the right applciation. 90% of engine wear occur at startup and W50s or 60 take ages to get to op. temp. Fine for the track,
But everybody, even Redline recommend to use their Shockproog oils in gearboxes. All sorts of claims about helping synchros etc. But look at their website (US) and it says not to be used in synchro gearboxes...but Aus says to use it. Plus too many tales of things going bang.
I will stick with Castrol for everything, its just what im comfortable with and to date has been good to me :O The only other engine oil i have used is Mobl 1, but cant find anywhere is Vic that sells the higher viscosity that it is available in
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
