Alsd were a option and expensive too.
Type M are turbo, NA's could be optioned with this and like all options it was up to the original buyer what your car has.
Options that I know of from factory (Nismo had others as well)
Sunroof
ABS
Alsd
Front lip (S2)
Rear Pods
Side skirts
Cruise control
Fog lights (S1)
Front bar (S1) dont know if S2 had front bar option aside from nismo
Steering wheel (S1)
Air Bags (S1)
Others?????
I thought the rear pods, skirts, and front lip were the M-Spec?
My 96 s2 has the M-Spec bits, but no sunroof or ABS (optional)
Some sites list 95 (1.5's) models as series 2, and also list ANY series two as M-Spec. I thought the whole bodykit on the series2 was the M-Spec option? It probably had stiffer suspension or something too?
FAST shows my car as being a "GTS25TM1"
Curious to know if other series2's don't have the "M1" bit at the end?
it hurts...THERE IS NO SUCH THING AS an M-SPEC R33!
do you call a GTR a TGR just because its kind of similar?
it is type-m. period.
there are no 1995 series 2's...only the made up "1.5" which have the series 2 motors
Sideskirts and pods were an option, and a pretty common one.
hehe! OK! Type M it is!
So FAST says I have a gts25tm1, which i'm assuming is Type-M I, not II... which has the following options:
"Front spoiler, Rear window wiper, Anti-lock braking system, Navigation system, Ultraviolet reducing glass, Tinted windows"
I have the front spoiler, but does that include the skirts and rear pods? It seems that if you have one, you have them all?
Got wiper and UV glass (I think)
  • 1 month later...
It apears to have never been there. The MDF on the rear shelf appears to be factory with no hole for where the wiper would come from. The wiper stalk also does not have the rear control on it. ????
I haven't got the rear window wiper as well as no control on the wiper stalk...it gives the car a much sleeker and cleaner appearance from side profile. Its a 97 as well.
How can you tell a type m from the normal model?
one of the easiest ways with the 33 is to pop the bonnet, look down the passengers side of the engine bay, and if there is a turbo, its a type m, if there isn't then it isn't a type m.
the 32s have bigger brakes, leather triming inside (gear boot, steering wheel, and handbrake cover)
Well aparently the turbos are different not only in the plastic compressor but it is a different designed compressor fan as well, which isn't really surprising just not mentioned.
OK, so how do we tell if its a s1, s1.5??? if some or all of the parts match or dont match what has already been said about these.
i have a s1 (im sure) but some of these guys with s2's have similar htings to my s1 , but my car aint a s2. etc..
need a vin check somehow. i know holden do it.(to some extent). anyone got any ideas?
Hi there,
I'm new to r33'S, I'm in the process of purchasing a 96 gtst.
A little off topic but Question:
"What's happened to the Cruise Control in these things? I read a spec sheet and it said that the it wasn't even an option in the S1-S2."
Is this correct? If so WTF?????? My run of the mill turbo '88 Z31 has cruise control std......................
I've noticed the bracket for the cruise control cable is there
but no cable etc.
Anyone have C.C on an R33 GTS?
[ http://www.skylinesaustralia.com/forums/in...ic=9479&hl= a link but no real answer]
Mike.
Edited by Mike5444
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
