Can anyone provide me with the latency times for nismo 555cc RB25DET injectors please?
I reckon it would be sweet if there was a database for the most common injectors latencies and whatnot...
Double that request for Nismo 555cc injectors latencies.
I can't find that data anywhere.
come on.... someone must have latencies for yellow Nismo 555cc injectors.
Must be the one of the most common upgrades.
If anyone has them please have look in your PFC hand controller and see latency your tuner has used.
There are three people here waiting for this and probably more that will benefit from this information.
It will at least let us drive our cars down to the tuning shop with some peace of mind that the fueling is not excessively lean.
Once my car is tuned I will post up the latencies my tuner has used.
have you not tried googling? nismo 550cc lag time nismo 550cc latency etc. keep going till you find it, the truth is out there. That's what I've done every time I needed to know and injector lag time and it's never failed me.
Yep, tried the google. Nismo 555cc get a few more hits than 550cc but still no success.
Heaps of forum discussion, no solid data.
- Japanese instructions do not mention anything.
- No data on Nismo website.
- PaulR33 FAQ does'nt list 550cc Nismo injectors unfortunately.
(http://paulr33.skylinesaustralia.com/docs/powerfc-faq/powerfc-faq.htm)
If anyone is running yellow Nismo 550cc injectors the sharing of their PFC latency setting in this thread would be appreciated.
Incorrect latency settings can be fixed by compensating the fuel map but that is a less than satisfactory outcome to my mind.
Only data I can find is 0.710ms. However, I would personally prefer a more reputable source than this random thread. :(
http://forums.freshalloy.com/showthread.php?p=1452662
HAHA sorry i forgot :D
nismo 550cc 0.71 :P
Std lag times to calculate differrence; (for some reason i lost my second decimal place :( i will fix it asap
RB26DETT
440cc
0.77ms
RB25DET NEO
380cc
0.6ms
RB25DET NEO
380cc
0.7ms
RB20DET
260cc
0.7ms
SR20DET (s15)
480cc
0.5ms
SR20DET (s13)
370cc
0.7ms
SR20DET (s14)
370cc
0.7ms
CA18DET
370cc
0.6ms
2JZ-GTE
440cc
0.9ms
3S-GTE
540cc
0.5ms
4G63 (1-4)
510cc
0.8ms
4G63 (5-8)
560cc
0.8ms
13B-REW
prim 550cc
0.8ms
sec 850cc
0.7ms
EJ207 Sti
520cc
0.7ms
BLITZ PERFORMANCE INJECTORS
UNIVERSAL
1000
1.00
RB26 / CA
700
0.65
RB26 / CA
660
0.55
RB26 / CA
534
0.85
1JZVVTI
525
0.99
1JZ / 2JZ
540
0.56
SR / RB25
550
0.85
SR / RB26
850
0.85
2JZ
850
0.85
Interesting thread. My experiences with nismo 550's on a sr20 was that they lost the ability to deliver fuel properly below 1.45-1.55ms. That was firing the injectors sequentially on low impedance injector drivers.
So I am guessing the 0.71ms latency means time for the injector to change from closed to completely open... and not back to closed again.
I've read that some sard regulators are stable down to 1.1ms with stable fuel delivery, so the latency has got to be close on 0.45-0.5.
Cheers,
Ian
WTF... do nismo even make 550? isnt it 555cc? anyway.. im after the EXACT Latency times For Nismo RB26DEtt 555cc injectors. to re-configure the Power Fc..
Thanks Guys,
If anyone has 555cc injectors on the power fc and run them on an RB26DETT please goto your car and check the Latency time set into your hand cntroller hanks guys.,
  • 7 months later...
Hi Guys
Sorry to bring up an old thread, but i need a bit of help.
I will be installing my nismo 555cc injectors and setting up my power fc for the injectors in the next couple of weeks (running a HKS 3037 Pro S and all the supporting mods) before i book it in for a tune, i have worked out the injector correction and injector latency correction numbers that i need to change in the PFC, can somone please comfirm for me that these are 100% correct? :D
"INJECTOR CORRECTION"
- Formula = stock 370cc divided by nismo 555cc = 0.66cc x 100 = 66%.
So i would go into the power fc and change the INJ correction to 66%, correct?
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.71msec and stock is 0.52msec
- Formula = nismo 0.71msec minus stock 0.52msec = 0.19msec
So i would change the INJ Latency numbers for each injector to 0.19msec, correct?
Hopefully this can help people in the future that are looking for the correction numbers :).
By the way, someone should sticky this thread!!
Cheers
Edited by nizmo_freek
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
