^^^ dnt stress to much about the latency, your tuner can do it 90% of the cars (even tuned) that come to my workshop have not even had this set..... i always set it but at the end of the day it wont effect the car bugger all if you just want to drive it down to the tuner.
the important one is the injector correction.
  • 2 months later...
hmm... coz i swap the little rubber o rins from my stock ones and put them on my new ones... put a tad of vasoline on them so they slipped in...
dang are they stufed now if there locked??
wll i found that the car was WAY flooded........ like un believable...
not before i got startin it.. the 66% and .18 will be fine??
or shall i got 80% as some ppl i know run 80% and .00
cheers all..
  • 4 months later...
i have a set of deatschwerks 650cc side feed (red) rb25det injectors and im not sure how to set the lag/latency. the information i have is:
16v - 1.072
14v - 1.192
12v - 1.420
10v - 1.8
8v - 2.62
6v - 5.88
now how do i change that infomation into a ms reading that i can subtract the stock injector lag from to enter into my power fc??
i think i have a more complete voltage list like that in my email (cant check it right now though, at work) that goes from like 4v to 17v for ever 1v if that would help anyone help me, i can post later
Edited by ANVIL
I also have hi flowed red top injectors for RB25, mine are 680. i think red tops come out of some 300zx's and KA24 or whatever the 2.4l nissan donk comes in bluebirds and US-spec 240sx's
i know the correction will be 54% but unsure of the Latencies.
i'm going buy what Uras (trent) said and hope the tuner will deal with it...
  • 5 months later...
just got an email from Deatschwerks which gave me this info for redtop side feeds the time would be .64ms
so:
.64 - .52 = +.11
i will post all the voltages too when i get home if i remember
ANVIL the voltages were posted for the DW red 650cc's above. I know it has been a while, but how did your RB run with these lag settings? And did you also change the latency settings "Inj Lag (ms) vs. BatV" to match the DW provided voltages??
  • 5 years later...
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
