Ok,
pooling our combined knowledge for a good cause - my savings!!
Im tempted to just go to autotint or whatever they're called (next to westate Autobahrn) in Nbridge, but is there anywhere better and/or cheaper around that I should consider.
FYI, they have an advert out the front for tinting FROM 199, though they quoted me $299/car.
https://www.sau.com.au/forums/topic/17379-best-place-in-perth-for-tinting/
I had my tint done recently by the guy that did JiMiH's
highly recommend him, he was cheap, can do all types of tints and was faultless. Took him about 2 hrs to do
it was $180 for my R32. So if you (or anyone) wants his (todd) number, PM me.
i used to take my cars to jamal from current trendz, but i havent been happy with his quality in the past year (2 out of the 3 cars i took there constantly bubble, and he wont fix)
:uh-huh:
well he said to me "if you have any issues give me a buzz". I figured it was worth the chance being only $180 for dark tint.
he works for a tint place and does cashies after work
Personally i like to deal with 'after work cashie' when i can, the service seems more personal, and they tend to take a lot of care knowing that you will recommend them, and you deal directly with them.
does that make sense? :P anyhow..will send the PM
i got complete mirror tinting and it is fully fully illegal, but i love it, but yesterday i started to rip it off
i am not sure who is doing mine, but JimH highly recommend that guy Zanda, i would go to him, might even do it myself next week
lata
Ive had peter garden do a couple of my cars, hes out in ballajura, does the 95% dark as hell tint, wierdly i never got a sticker ofr it on either car, got pulled over a couple of times but thtye never questioned it..
you can find him in the phone book..
Originally posted by zanda
AND the first ime you get pickd up for it you will have to get it all ripped off to get the sticker off!
dont know bout any of u guys but I had the darkest grade limos on 4 a year and a half and was pulled over 4-5 times and never got a licky - just lucky I guess!!
Originally posted by puckish
Sun Pro in Ossie Park.
60% heat rejection 99% UV.
Leagal and has a cool mirror finish that you can still see through.
HIGHLY Recommended but it ain't cheap.
had mine done there, price was ok but quality wasn't that good,
spears that look like / are at the bottom of my rear 1/4 windows look shit, and also the rear window theres bubbles with grains of shit under them etc...i gotta either go back to get it re-done for free or go somewhere else. they have a good range though from legal, to black as f--k and mirror, where u can't see through them at all even in daylight.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
