Hey guys,
My gtt has around 250kw at the treads with an aftermarket turbo, pfc and all. It was tuned with Shell V Power 98.
I was wondering if i run V Power Racing 100 at the drags, would it help or hurt the power output? is the different fuel gonna mess up the tune, a/f ratio and etc? hence good or bad for engine/turbo?
Cheers guys
Edited by BaysideBlue
  • Replies 42
not a ad idea at all. it will not improve your performance at all but will make your safety margin slightly bigger. will also not mess up your AFR's.
I agree, you will improve your protection from pinging but you may actually lose a couple of killerwatts due to to fuel being less volitile....(burns slower so you need to add more timing to compensate) but i doubt that you would notice as it would be more to do with air temp/relative altitude than 2 RON difference in fuel.
Andrew
Stick with your usual fuel and octane booster. You won't gain 7 points on anything but base unleaded, maybe 2-3 tops on 98 octane.
I recently ran some nulon pro strength through mine on the dyno and it had no effect on the mixtures and increased the detonation threshold significantly (enough that i could add 5 degrees of timing before any audible pinging).
Adding toluene effects your mixtures as you have to add so much of the shit to get a significant increase in the RON of your fuel. Were talking 5-6 litres per tank of fuel (thats near enough to 10% by volume) to get a couple of point increase.
and if you stuff up things can go pretty wrong. i was asking my mechanic about toluene and he said it is better to stay away from it cause a small mistake can have large consequences.
Depending on how far you want to go, toluene is the best option. It only aided F1 back in the 80's to achieve the high horsepower figures they had and ran.
Problem with the octane boosters is the higher the initial ron of the fuel the lesser increase you see from adding it.
mad082 can you explain your mechanics reasoning for not using/advising toluene?
V-Power will actually LEAN OUT your mixture, not richen it up.
Not by a lot, but mine went from 12.0 to about 12.2 on the Optimax Extreme.
When I put it in my car, I normally leave the AFR and just add some timing.
But I don't use it often.
thanks guys for the replys.
so using 100 octane fuel on 98 tuned engine will lean out the mixture which would increase safety margin but need to adjust timing. how exactly do i do that?
and also, is it worthwhile doing (pay the extra cost for v power racing + adjusting timing) for the so said slight increase of safety margin, without any real performance increase over the quater mile?
rule of thumb is if you are asking how to tune your car then dont do it yourself. Get a tuner and a dyno
Edited by Bl4cK32
higher-octane fuel will lean out the mixtures, except as the the octane level is the fuel's rating of resistance to detonation it will probably be safer for the motor.
However, using a higher octane fuel without a tune may not see any gains because the burn rate will be reduced and the motor will not be running optimally. Best bet, just run 98octane what your car was tuned with.
If you really must, an amateur way of adjusting ignition timing to get the most out of a higher octane fuel is done by moving the CAS anti-clockwise slightly, test driving and repeat until you reach an acceptable knock level i.e. 20-30. Or read up on paulr33 PFC guide.
Edited by BAMR33
ok sounds like theres no point using v power racing without a tune or at least adjust timing then.
thanks i will try that.
if thats how your planning on doing it. Dont bother. Unless you got a timing light and your checking base timing as you go, its not worth it mate. Will probably cause more problems then its worth.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
