Hey guys,
My gtt has around 250kw at the treads with an aftermarket turbo, pfc and all. It was tuned with Shell V Power 98.
I was wondering if i run V Power Racing 100 at the drags, would it help or hurt the power output? is the different fuel gonna mess up the tune, a/f ratio and etc? hence good or bad for engine/turbo?
Cheers guys
Edited by BaysideBlue
  • Replies 42
not a ad idea at all. it will not improve your performance at all but will make your safety margin slightly bigger. will also not mess up your AFR's.
I agree, you will improve your protection from pinging but you may actually lose a couple of killerwatts due to to fuel being less volitile....(burns slower so you need to add more timing to compensate) but i doubt that you would notice as it would be more to do with air temp/relative altitude than 2 RON difference in fuel.
Andrew
Stick with your usual fuel and octane booster. You won't gain 7 points on anything but base unleaded, maybe 2-3 tops on 98 octane.
I recently ran some nulon pro strength through mine on the dyno and it had no effect on the mixtures and increased the detonation threshold significantly (enough that i could add 5 degrees of timing before any audible pinging).
Adding toluene effects your mixtures as you have to add so much of the shit to get a significant increase in the RON of your fuel. Were talking 5-6 litres per tank of fuel (thats near enough to 10% by volume) to get a couple of point increase.
and if you stuff up things can go pretty wrong. i was asking my mechanic about toluene and he said it is better to stay away from it cause a small mistake can have large consequences.
Depending on how far you want to go, toluene is the best option. It only aided F1 back in the 80's to achieve the high horsepower figures they had and ran.
Problem with the octane boosters is the higher the initial ron of the fuel the lesser increase you see from adding it.
mad082 can you explain your mechanics reasoning for not using/advising toluene?
V-Power will actually LEAN OUT your mixture, not richen it up.
Not by a lot, but mine went from 12.0 to about 12.2 on the Optimax Extreme.
When I put it in my car, I normally leave the AFR and just add some timing.
But I don't use it often.
thanks guys for the replys.
so using 100 octane fuel on 98 tuned engine will lean out the mixture which would increase safety margin but need to adjust timing. how exactly do i do that?
and also, is it worthwhile doing (pay the extra cost for v power racing + adjusting timing) for the so said slight increase of safety margin, without any real performance increase over the quater mile?
rule of thumb is if you are asking how to tune your car then dont do it yourself. Get a tuner and a dyno
Edited by Bl4cK32
higher-octane fuel will lean out the mixtures, except as the the octane level is the fuel's rating of resistance to detonation it will probably be safer for the motor.
However, using a higher octane fuel without a tune may not see any gains because the burn rate will be reduced and the motor will not be running optimally. Best bet, just run 98octane what your car was tuned with.
If you really must, an amateur way of adjusting ignition timing to get the most out of a higher octane fuel is done by moving the CAS anti-clockwise slightly, test driving and repeat until you reach an acceptable knock level i.e. 20-30. Or read up on paulr33 PFC guide.
Edited by BAMR33
ok sounds like theres no point using v power racing without a tune or at least adjust timing then.
thanks i will try that.
if thats how your planning on doing it. Dont bother. Unless you got a timing light and your checking base timing as you go, its not worth it mate. Will probably cause more problems then its worth.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
