always go to a specialist if you possibly can.
You will always be better off going to a specialist than a mechanic. If there is a price difference it will be negilible and at least you know if there is a problem afterwards they will be able to take care of it themselves, not try and pass the buck on to a parts supplier etc
  • Replies 49
oh and .. if it ( the CV joint ) was on the front ?
if so its about 99% certain you will need to get a wheel alignment
even if it was at the rear I woudl check it out if I were you
eesh.. even THINKING of doing CV joints leave me cold
yea was front passenger side.
Actually replacing the boot wasn't that bad,
it was cleanin the grease out of my mags that was the most pain.
Yea we got a wheel alignment two days later drives much betta now..
  • 3 months later...
Hi
Sorry to bring up an old topic but i had my CV boot go on the drivers side so i booked it into a CV specialist to have both sides done (boots only as i had the magna done without replacing the joints with no problems 300,000k).
He complained about it being a prick of a job as he needed to take the shafts out (Why i don't know) and after all that only did one so i have to take it back.
Q.
Do the shafts have to be taken out
If so how are they held in.
Thanks
Phil
Hi
Q.
Thanks
Phil
i dont know if they need to be removed to do the cv boots but i do know how the shafts come out.
both sides u need to take the top control arm off and steering rack arm and coilover off the strut, then u can lever the hub towards the outside of the car and that will allow enough room to get the spline from out of the brake hub (u gotta undo the big hub bolt first as its holding the shaft in and it will be bloody tight, best bet is a big socket set, i use a 3/4 inch set for this, or get a long breaker bar and it should do the trick).
the drivers side is held into the front diff by just a spline that is a tight fit, u need 2 levers close to the sump/diff and lever the axle out as u pull it outwards and it will pop out.
the passenger side is a flange to flange and 6 bolts need to be removed close to the sump and it will come off easy.
hope it makes sense and gives u an idea of the job
hey guys i have done a few cv,s alot of the time you can just use a stretch fit boot $25 easy as to fit. alot of the time the cv people only do the same as what us mechanics do. but say they serviced the cv. really there is nothing to service on a cv. if it is knocking you buy a replacement end which is held on by a circlip. really there is no diff between a cv specialist and what a mechanic does. as for is it a hard job not really should take no longer then 40 min a side to remove shalft and replace both inner and outer boots and refit .allow will take a bit longer to do at home with no air tools or hoist . well that my 2 cents anyway cheers bernard.
very true bernard, it takes longer to get the shaft out that it does to replace the boots!
unique1 you can also get the front shafts out without removing the upper control arm, steering and shock - you can get enough space by disconnecting the sway bar and the lower control arm ball joint, you can then pull the hub backwards and out pretty easily as it pivots on the steering arm, shock and upper control arm.
interesting, thanks Duncan ive had the motor out a good 10 times and removing the front shaft on the drivers side is a pain in the arse and i might try your method next time (if there is a next time, i am hoping not, lol)
Thanks heeps gies >_<
He has replaced the outer boot only on the drivers side as he did not know how to take the shaft out ($90)
Went back today to have the passenger side done he unbolted it at the sump replaced inner and outer ($110)
shame i haden'tgot on here earler i could have given him some information
I think he was confronted with something a bit out of the ordenary and didn't want to damage aney thing
Aneyway a big thanks to all who replied ;)
thanks
Phil
  • 1 year later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
