Below is the wiring diagram which enables the power fc to function properly in a manual stagea without throwing the engine checklight.
I have used this wiring circuit in three series 2 25t rs four "s" stageas, all with great results.
However i cannot attest to its viability in a converted series 1 manual stagea.
https://www.sau.com.au/forums/topic/175032-power-fc-in-a-25t-rs-four-s/
Hey Andy, I figured out something similar to achieve the same results.
I just put a 510k ohm resistor from pin 51 on the ECU to ground, because pin 51 has around 5V coming out of it
and you just have to lower that voltage to around 3.7v to turn off the engine check light.
It seemed to affect the idle slightly aswell, did you notice that?
But besides that, it runs fine, just have to get my cold start sorted out.
i can attest to the workability of the "secret squirrel tweak" as i have it installed on my car and it is easy to fit and allows you to tune the power fc as you would in any other car.
cheers oxford
I can confirm that the method that I have used in a series one converted to manual
does work.
But if the method Andy has shown is a better way of doing it, I'll give it a go.
Anyone know if it would be the better way of doing it?
does work.
i have no problems with idle or any other side effects.
the way it works is that the zener diode (or diode's if you use a combination to achieve 10.3V) have a break over voltage of 10.3V, meaning that only 3.7V (14-10.3) or there abouts makes it to pin 51. the resistor to earth is to stop any current from flowing through the ECU.
My cold start is a bit funny as it still needs sorting out, but once it's warm it idles fine.
What I noticed was that when I put the resistor in, the idle changed (lower or higher not 100% sure now).
But I might give your method a go when I get some spare time, see if it makes any difference.
the R34 powerFc pin 51 goes to the traction control so if you plug it in it will run the engine no problems (at least on a series 2 stagea and presumably on a series 1) but the engine check light will be lit. EGA4IT's circuit will provide the 3.7V to get rid of the checklight.
  • 3 months later...
Guys how does the PFC react to the GTR gearbox and 4x4?? Are there any long term issues assosiated with this mod and the driveline?? Does the GTR PFC control the Atessa in anyway and if so I would asume the GTT PFC wouldn't do the same job?
Cheers
Dave
Cheers
Dave
If you're still thinking of getting the Autech Stagea, then the PFC for an R33 GT-R will work regardless of if you buy the series 1 or series 2 Stagea. It's a direct fit and no mods need to be made.
If you're getting a series 2 RS-Four S, then I believe that once you've done the mod outlined by EGA41T, wolverine and beastien, then you won't have to worry about the ATTESA - the ATTESA control is separate.
The attessa can be run by any ecu easy, all it needs is the TPS wire split into 2 and one goto the ecu and the other to the wire than runs to the rear attessa ecu to give it the tps signal. 4wd will work perfectly :) this works on haltech, autronics, wolf, etc. I have done it and it works perfectly.
ill find the colour of the wire that u need to connect the tps signal too and post it on the forums for future reference :rofl:
Edited by unique1
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
