  • Replies 48
My understanding is the same as Ben's. As another analogy (an exaggerated one to help illustrate the point), imagine two different-sized air tanks. One maybe the size of a Coke bottle, the other the size of the tank on the back of a petrol tanker.
Pressurise both to a given pressure, say 20psi.
They're both at 20psi PRESSURE, but the difference in VOLUME is massive.
I always like the water tank analogy.
You got a big water tank full of water
you punch a small hole in the bottom of it with a nail - how much water comes out ?? Not much.
then you get a huge hole saw and put a 5 inch hole at the bottom - how much water comes out ?? Heaps
The pressure in each circumstance was the same - 1 bar (Atmospheric pressure I think is 1 bar)
Correct, 1 bar or 14.7psi IIRC is atmospheric pressure at sea level.
An interesting side note which many people don't think about is that as a result, when your boost gauge shows, for example, 1 bar of boost, the intake manifold is actually at 2 bar, because you're adding 1 bar of BOOST to the 1 bar of atmosperic pressure.
I guess that means drivers of NA vehicles could tell people they're running 1 bar through their motor... :)
Yes, just like if a tree falls in the woods, does it make sound??? :confused:
Back to the question from evl r33, don't look at numbers from differing dyno's and base everything on them. They are simply a tuning device. My car made 160kw on rwd but then suddenly made 180kw on 4wd at a different place? That's right, the transmission somehow makes power now... :confused:
Originally posted by fatz
kinks
give me 10 seconds and i will show you how to drive a GTR
then you will know how txo get it sidways
pete
I've been for a ride with you in the streets of mudgee, you took blackbart and I for a spin. Ages ago :D
Back to the topic at hand - Tex and I were debating this last night. When you're talking about how much power an engine's making in terms of the turbo side of it you care about two main things - boost pressure and intake air temperature. Remember that boost pressure is measured at the manifold, after the throttle body. Same with intake temp. At that point, everything else is constant because the heads are the same as before, the cylinder filling will be the same. This means that for a given manifold pressure you will get a constant VOLUME of air going into the engine whether your turbo is big small or spraypainted bright purple. With a bigger turbo, the air isn't heated as much and therefore because it's denser, you get more MASS air flow into the engine - which at the end of the day should give you more power.
As for why two stock turbos running 1 bar gives more power than two bigger turbos running 1 bar I'm not sure. It must come down to tuning differences or - more likely - dyno differences. Remember that dynos aren't comparable a lot of the time - you only have to see Secoh's "dyno proven" 195rwkW VW Beetle to know that dynos can tell fibs. (although I think that power figure was wind assisted) :P
You also have to remember a large turbo is going to give you a cooler charge of air aswell as an increased volume.
The cooler the air is the more dense it is.
So more cooler air = more power :O
Also another thing to note is peak power is not the only thing that matters the area under the power curve is what makes a difference to. The large the area under the curve you have a larger power band.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
