Hey i recently had a GT35/40 turbo on my rb25 but it had a .63 ex housing when i bought it, well that was abit responsive and not ideal for the power range im after, so it is now sold.......... my issue now is im not sure whether to buy another GT35/40 turbo with a larger ex housing OR use a T04Z with similar size ex housings.....anyone no which would be a better choice???? Power output im chasing is 450hp at wheels, lag could be an issue, so thats why im asking for any opinnions.... cheers guys.. 35/40 or T04Z????? oh n i forgot to mention, its a t3 flange at the moment but am changing that to t4 at present so both turbo choices will be used in conjunction with a T4 flange
https://www.sau.com.au/forums/topic/175853-turbo-choice/
I'll help you see the silly.
T04z - upto 450rwkw.
So if you only want 330rwkw, then its not smart to go a big huffer like the t04z.
The GT35 is far better suited to that range and will be more responsive and feel a truck load better for only 330rwkw.
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3220471
gt3540 82 rear on a top mount manifold well designed ie: 6boost, external gate, and 19psi roughly? :dry: As sugested much much better than the T04z.
1+ the T04Z prefers 24psi and upwards of boost where as the 3540 will spool earlier and less boost to make better power? as far as i can gather
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3220596
What he forgot to mention is the engine is about 2.7L... If that changes which turbo to go for or not I dont know. But its handy to have some specs on the engine.
how does rb26 crank and rods = 2.7L?!?
i would definately go the gt3540r, supports your aimed power output with better response and also suits your engine build better, t04z is too big and i would imagine you would start breaking internals :rolleyes:
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3221383
na its 2.6 not 2.7...cheers nismoid, your a legend.. the .63 ex housing on my previous 35/40 would start to make boost at 2800rpm, im looking for one that comes on song about 4000rpm.. give or take. but ideally if the target hp (450hp) is reached then i'm happy either way... next is the fact the manifold has a t3 flange, with previous turbo (.63 ex housing) the housing and manifold and top of dump pipe would glow red at cruise on dyno, not even giving it a power run, was thinking maybe the t3 flange is abit restrictive so enlarging to t4 flange might have to be the go this time round also.????????????
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3221976
um not on cruise they dont, when i told the tuner he stopped n let car idle till things stopped glowing, wasn't even boosting it, my mates hi mount turbo sr20 that was there with me only glowed once they did some full power runs
Yes they do champ. At cruise the AFR's are considerably leaner and as such, make for much hotter exhaust gasses. Your manifold is more likely to glow like that at part throttle and cruising than under medium to full load.
Fact.
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3222304
ok, my bad, its just that i thought of it this way........ with power comes heat, for example lets say we have a car that makes 400hp flat out, and to keep it simple maths we'll say it uses 100hp at cruise which is only a 1/4 of its potential hence internal combustion temps not being that hot so i didnt think the manifold would glow however at full noise your using 400hp its now making 4 times the power and your internal combustion temps have gone through the roof hence exhaust metals changing colour. this is the way i thought it was, regardless of mixtures being lean or rich, at the end of the day if your cruising you wouldnt think the internal temps would get hi enough to glow manifold unless there was a build up of....back pressure due to t3 flange or .63 ex housing?? now i may be wrong but i dont remember seeing cars exhaust glowing on cruise unless there was a restriction....???????? make any sense?
https://www.sau.com.au/forums/topic/175853-turbo-choice/#findComment-3225754
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
