4wd Relay Clicking At Idle
wolverine
Dave,
good work on finding a fix for the clicking noise, I have the same problem on my r32 gtr and was planning on buying a second hand attessa unit and fitting it to my car. After reading this thread I will now just try and re-charge the accumulator that is currently on the car. Just a a quick question, what presssure did you fill the accumulator to? I read on the aristo link you posted that 1000psi seems to be norm for those cars, is that same pressure you used on you accumulator?
Thanks
Aki
  • 4 weeks later...
Problem solved!
So here's the solution if you have this clicking relay problem (and it is because of the "flat" accumulator - probably is though):
- with engine/ignition off, open hydraulic bleeder connection on the underside of the ATTESA assembly (just above the rear diff')
- unscrew the accumulator, may lose a few drops of ATTESA system fluid?
- recharge or replace the accumulator
- replace the O-ring on it if it is looking cracked
- screw back in :O
So far mine is fixed, no 4wd light, and the relay clicked only perhaps twice(?) that I noticed on a 45+ minute drive. At last got rid of that infernal clicking!!!
PS For those looking for a way to get their cylinders recharged... check out this forum topic (sorry mod's it's on a Toyota forum - don't think there's any conflict of interest there though!). I'm just about to send the guy who does the recharging ("Mooty") my flat accumulator cylinder, to use as an exchange unit, and he says he will soon get back into the recharging and do ATTESA too. So hopefully we will soon have access to an exchange service which can recharge the cylinders for under $150 :)
I have been chasing this problem for 4 years and just fixed it 2hrs ago!
Big thanks to Dave B for finding the fix.
Just replaced my accumulator and no more ETS relay clicking in the boot! I replaced mine with a secondhand one but they are available new from Nissan.
Big thanks to Ben from Quatromotive in Northgate Brisbane who can source the accumulator and remove & refit!
http://www.quattromotive.com.au/
Cheers Dave B happy as :)
Dave,
Thanks
Aki
Great stuff guys, good info' on the units from Nissan and I will have to check out that web address... sorry I missed your reply Aki but in answer to your question: I don't know what the pressure is because I replaced my accumulator with a used, known-good second-hand unit. 1,000PSI sounds like a lot but could be right. Hopefully if there is a place who can recharge them they will know.
Cheers Dave B happy as :blink:
Great news! Glad it worked :)
  • 2 months later...
Its so funny cause i had the exact same problem and so many people on the forums said it was normal.
I remember when i first got my Gtr34 it never used to do this clicking thing in the boot and then after the first engine failed the car sat for so long so i presume thats when the accumalator lost its pressure ...
Then when i got the second motor in and started driving her around town running it in i remember pulling up to a robot and hearing this constant clicking sound it used to bug me terribly.
So i posted a few questions and never had them really answered.
I even used examples of other gtr34's attessa system pump sounds and never was the relay noise ever mentioned.
As fas as i know the pump should engage once when the car is just been started and then you wont hear it again till some track use or hard driving with some major turning and high speed cornering then a few seconds later after you stop and let the car idle you shouldnt hear the relay clicking you should actually hear a pump high pitched whine coming from the rear of the car and that means its charging up the attessa accumalator.
Thankyou for taking the time and pain staking process of trying to solve this problem.
I remember on gtr.co.uk there is a guy there called joker69 or something like that he also had the same problem and replaced his attessa accum.... and viola problem solved amazing.
i would still suggest bleeding the system after fitting the new unit as you will get air trapped in the system and bleed the whole system starting from the resevoir and then the pump at the back and then finally the front Bleed nipple that is next to what they call the clutch pack on the front transfer case.
Thankyou again when i get my car on the road again maybe in a year or so i will post when i replace the accum and let you guys know what results i get as well.
Cheers and well done...
thanks everyone for the info, ordered a new accumulator from Nissan today, $380, and a new relay to be sure $40. Didnt want to take a chance on a 2nd hand unit as they are all over 10 yrs old by now. But seems to be an opening for a business if they can get a recharge service going.
Problem solved!
- screw back in :)
PS For those looking for a way to get their cylinders recharged... check out this forum topic (sorry mod's it's on a Toyota forum - don't think there's any conflict of interest there though!). I'm just about to send the guy who does the recharging ("Mooty") my flat accumulator cylinder, to use as an exchange unit, and he says he will soon get back into the recharging and do ATTESA too. So hopefully we will soon have access to an exchange service which can recharge the cylinders for under $150 :P
wow, thank you so much!! i had the same problem for the last 4 years with no repercussions. but the last 2 weeks, its getting worse and worse, it clicks every 5-10 sec and, i loose power steering, radio shutdown, my apexis panels shut down and my lights flicker every where !!
my car is getting new turbos and i asked my mechanics to change my accumulator at the same time !!
Its gonna be weird not hearing the sound anymore after 4 years of annoying clicks.
Marc-André from Montréal, Canada
got the accumulator ready to install, for those who have done this, what tool did you use to remove it? oil filter wrench ? and could you turn it/get leverage without lowering the diff ?
Definitely can do on the car, without removing anything (well having a hoist obviously made it easier). I removed one using a G-clamp; but perhaps you could even get it undone using an oil filter wrench... I can't remember what the mechanic used who undid mine on the car but it may have been an oil filter wrench.
  • 4 months later...
  • 3 weeks later...
  • 3 weeks later...
update:
Replaced the actuator 6 months ago due to the relay clicking, new from nissan.
All fine until a month or so ago, clicking stated up again, but only on hot days and only after driving for more than approx 30min. And even then, doesnt always happen, maybe on 1/3 of long drives. The clicking occurs rapidly on accel and when snow button is pressed whilst idling. If I turn off/on engine for a few minutes it come good. This all matches the pattern i had before i replaced accuator. I would have thought if actuator went, it wouldnt be an intermittent problem, but always ? For those who fixed theirs with actuator, was it clicking at all times ?
Not keen to spend another $350 on a new actuator.
It appears heat related, possibly pump or electrical ? Any ideas. And yes, new fluid, bled many times from both nipples...
  • 3 years later...
Hi All,
Anyone removed the accumulator without lowering subframe/diff?
I tried this today on my R32 Gtr and couldnt get a good grip on the accumulator with G clamp.
The accumulator seems to be stuck/seized at the thread.
Any advice is helpful thanks.
Edited by keysersoze
When I said "I" removed it, that was a bit of a furby... I watched the mechanic do it with the car on a hoist. I have a vague recollection of him scratching his head for a couple of minutes, and saying something like "hope we can do this without dropping the diff", but then I pretty clearly remember it only took 5 minutes so no diff removal just a bit tight.
    • Blitz ER34 at some point hopefully, should be allowed in Gr3 if they do.
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
