yeah half cage is ok, I have a full cage for mine, but the front half gave me the shits on the street as the drivers side 'leg' is pretty close to the throttle and kind of annoyed me, but it was definately much better with the full cage. so if you are getting a cage I say go full cage with front half removable. Car is a little stiffer with the cage and if I roll it over it should hopefully stop me dieing. plus it gives me a handy spot to mount my camera! :D
if your still free and in the country...come whoop all our asses in rd3 of the state championships! 29th and 30th september.
I would rather be beaten by another nissan then a stupid toyota.
Now now Michael, thats not very nice of you. You've hurt my poor cars feelings now...
wow...im suprised your on here buddy.
this is my territory...you cant come on here in nissan country. I dont hang out on supra forums and what not.
but its true...id rather be beaten by a nissan then a toyota.
Cheers Angus!
Are there any good places in Sydney to have chat with about the cages?
hey mate west side mufflers at padstow.
they will do whatever you like when it comes to cages, they do alot of approved cages for race cars from all different classes
9773 7244
Edited by Angus Smart
specs John?
Angus,
Cheers mate!
Car-
1993 Toyota JZX90 Mark2
Engine-
1.5JZGTE 445rwhp @ 18psi
JE 86.5mm forged pistons
HKS 264 degree intake and exhaust cams
GReddy 1.4mm metal headgasket
Titan vernier cam gears
Custom plenum chamber
Nissan VH45 throttle body
Power FC
GReddy front mount cooler
HKS T04R turbo kit
Sard 650cc injectors
Custom 85mm radiator
GReddy oil cooler and remote filter
Blitz twin plate clutch
R154 5 speed gearbox
Suspension-
TEIN Circuit Master coilovers
Cusco front upper camber arms
Cusco tower bars front and rear
Ikeya Formula rear upper camber arms
D-Max rose-joint rear suspension kit
TRD LSD 4.3 ratio
Alcon 4 piston front calipers, 343mm rotors
Supra 2 piston rear calipers, 324mm rotors
Braided brake lines
Performance- Qld Raceway
National circuit- 1 min 16.3 sec
Clubman circuit- 57.22 sec
Sprint circuit- 54.36 sec
Sportsman circuit- 54.14 sec
Edited by Stupid Toyota
Car-
Engine-
Power FC
HKS T04R turbo kit
Suspension-
TRD LSD 4.3 ratio
Alcon 4 piston front calipers, 443mm rotors
Braided brake lines
VERY VERY NICE !!!
AWSOME LAP TIMES TOO!!!
There the kind of lap times we need to get to.
Fantastic job
cheers russ
HA! i knew it, its the nissan throttle body thats making the toyota so fast!
I agree 100% definatley the Nissan throttle body helping with the speed. Very impressive lap times there will look forward to seeing your car in action sometime soon. I hope i can match or better those times when my car is finnished (depending on driver skill) as it will be a bit demoralizing being beaten by a toyota little own a bright pink one. :)
update.
no more main parts yet! :)
windows are here, dash is in and wired (finishing of the stack set up)
seat and pedal box in, need doors and suspension!
BTW car may be on show at the tokyo autosalon in January! haha somehow i dont think it will look as good as the new 2008 gtr launch!
cheers russ
still on track for 15th hopefully (shakedown only though)
Car-
Engine-
Power FC
HKS T04R turbo kit
Suspension-
TRD LSD 4.3 ratio
Braided brake lines
Awesome times, Slicks or semi slicks??
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
