it may seem fine. and laser alinger may be top shelf for a truck or whatever and maybe some laser machines are better than others. this was the latest beissbarth machine. maybe 1 month old when I used it. and it doesn't take a genius to figure out where they fall down. they have those 4 massive things hanging off each wheel so the slightest movement with the car or someone farting etc sets them moving and figures bounce around. old school is best. trust me. we are talking tenths of a mil in measurement either so the amount of accuracy is crucial and those type of machines just don't have it.
I'll see if I can get you a pic of the traction rods.
there you go (it's the gold ikeya arm):
hey bb, thanks for the pic of the traction rod, though i would consider it more of a camber rod. The whiteline rear camber kit allows you to lengthen or shorten that arm.
About the laser alignment, which i use myself when i go to bridgestone, what you have posted is pretty ridiculous. I mean its not like i tighten the nuts while the numbers are changing or someones farting lol. Having done over 5 alignments my self and working progressively through alignment settings from pretty conservative to now a reasonably aggresive setting, i have no doubt in the equipment.
On the other hand i dont believe the string method to be a bad one, and might give it a shot in the future to see if there is any improvement to be had. On the other hand i pay nothing when i go to bridgestone so i might just keep doing that.
I also think the fine measurements u are talking up are not that fine, i mean say u ended up with 2.0 front neg camber RHS and 1.9 on the LHS id bet my left nut u/me whoever couldnt tell the difference.
cheers bb
lol, consider it a salami rod if you want. it's an upper control arm, or traction rod or toe control rod. the main upper control arm adjusts camber. the traction rods mainly affect toe and the angle of the upright, not camber.
as for fine measurements. 0.2mm of toe makes enough difference. think about it. 0.2 of a milimetre. laser alingment in my experience is just not reliable and repeatable. hey I was a big fan until I started doing more and more stuff with it then I realised that it just wasn't repeatable. plus it takes longer for me to set-up than string line or set-sqaure type and when under the car on the lift and your head breaks the beam that is pretty annoying. look if it's my camary or whatever sure I wouldn't have a problem using it. but for the GTR manual is best. have a look at giants experience with laser equipment.
I'm never getting lazer alingment again. the cocks can never get it right, and also cough and spit the dummy when you tell them exactly how you want it.
surely i could go to another place, but i agree with richard here, the old school way is still top notch! And just found out my dads mate used to set up john bowe's car many many moons ago,
yeah it's easy to do. as long as you know where and how to adjust your various suspension arms, and how to read you can do it. knowing what is a good setting for any given part of alingment is a different matter. it takes experience, time in the car etc to find what works, but you can usually bludge some good starting points from somone.
you want something like this basically:
or like this even better:
i have just bought a smart tring set up out of the states, but up until now have been using curtain rods and string (cost about $30) :)
another big issuee with laser stuff is attachment to the rim, if there not careful or if your rims dont have a good lip on the rim( eg r34 rims), they fu@#k it up everytime.
russ
the ones I posted are ikeya formula. russ's ones are smart string. google smart string alignment you'll find it.
the ikeya one is about $400 for a full set.
but you can make your own pretty cheaply with just some nice metal rulers, some tubes and some string.
bear in mind the smart string $400 is USD. and also to do camber you'll need a camber gauge another $200odd USD.
the ikeya one is a bit cheaper at about $400 delivered for the "full set". and it can do camber too.
http://www.ikeya-f.co.jp/en/product_notice...a-one_gage.html
basically you need to measure the camber at different steering angles then apply a formula. in a workshop you have the car on a degree plate. you turn the wheel 20degrees, measure, turn it 20 the other way, measure and they usually have a thing there to calculate it.
might have a read into that ikeya one. thanks bb.
suppose there's no way of doing castor?
i'm also thinking, wouldn't it be 'ideal' to have the car on axle stands while doing any sort of alignment (not in mid air, but just to re-seat the wheels on the surface)? or to at least do the alignment, roll back and forth and re-check?
Bugga to the caster i just knew it wasnt going to be as easy as that :-)
And i would think you would need the wheels with the weight of the car on them to set it up, bump steer and all that
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
