it may seem fine. and laser alinger may be top shelf for a truck or whatever and maybe some laser machines are better than others. this was the latest beissbarth machine. maybe 1 month old when I used it. and it doesn't take a genius to figure out where they fall down. they have those 4 massive things hanging off each wheel so the slightest movement with the car or someone farting etc sets them moving and figures bounce around. old school is best. trust me. we are talking tenths of a mil in measurement either so the amount of accuracy is crucial and those type of machines just don't have it.
I'll see if I can get you a pic of the traction rods.
there you go (it's the gold ikeya arm):
hey bb, thanks for the pic of the traction rod, though i would consider it more of a camber rod. The whiteline rear camber kit allows you to lengthen or shorten that arm.
About the laser alignment, which i use myself when i go to bridgestone, what you have posted is pretty ridiculous. I mean its not like i tighten the nuts while the numbers are changing or someones farting lol. Having done over 5 alignments my self and working progressively through alignment settings from pretty conservative to now a reasonably aggresive setting, i have no doubt in the equipment.
On the other hand i dont believe the string method to be a bad one, and might give it a shot in the future to see if there is any improvement to be had. On the other hand i pay nothing when i go to bridgestone so i might just keep doing that.
I also think the fine measurements u are talking up are not that fine, i mean say u ended up with 2.0 front neg camber RHS and 1.9 on the LHS id bet my left nut u/me whoever couldnt tell the difference.
cheers bb
lol, consider it a salami rod if you want. it's an upper control arm, or traction rod or toe control rod. the main upper control arm adjusts camber. the traction rods mainly affect toe and the angle of the upright, not camber.
as for fine measurements. 0.2mm of toe makes enough difference. think about it. 0.2 of a milimetre. laser alingment in my experience is just not reliable and repeatable. hey I was a big fan until I started doing more and more stuff with it then I realised that it just wasn't repeatable. plus it takes longer for me to set-up than string line or set-sqaure type and when under the car on the lift and your head breaks the beam that is pretty annoying. look if it's my camary or whatever sure I wouldn't have a problem using it. but for the GTR manual is best. have a look at giants experience with laser equipment.
I'm never getting lazer alingment again. the cocks can never get it right, and also cough and spit the dummy when you tell them exactly how you want it.
surely i could go to another place, but i agree with richard here, the old school way is still top notch! And just found out my dads mate used to set up john bowe's car many many moons ago,
yeah it's easy to do. as long as you know where and how to adjust your various suspension arms, and how to read you can do it. knowing what is a good setting for any given part of alingment is a different matter. it takes experience, time in the car etc to find what works, but you can usually bludge some good starting points from somone.
you want something like this basically:
or like this even better:
i have just bought a smart tring set up out of the states, but up until now have been using curtain rods and string (cost about $30) :)
another big issuee with laser stuff is attachment to the rim, if there not careful or if your rims dont have a good lip on the rim( eg r34 rims), they fu@#k it up everytime.
russ
the ones I posted are ikeya formula. russ's ones are smart string. google smart string alignment you'll find it.
the ikeya one is about $400 for a full set.
but you can make your own pretty cheaply with just some nice metal rulers, some tubes and some string.
bear in mind the smart string $400 is USD. and also to do camber you'll need a camber gauge another $200odd USD.
the ikeya one is a bit cheaper at about $400 delivered for the "full set". and it can do camber too.
http://www.ikeya-f.co.jp/en/product_notice...a-one_gage.html
basically you need to measure the camber at different steering angles then apply a formula. in a workshop you have the car on a degree plate. you turn the wheel 20degrees, measure, turn it 20 the other way, measure and they usually have a thing there to calculate it.
might have a read into that ikeya one. thanks bb.
suppose there's no way of doing castor?
i'm also thinking, wouldn't it be 'ideal' to have the car on axle stands while doing any sort of alignment (not in mid air, but just to re-seat the wheels on the surface)? or to at least do the alignment, roll back and forth and re-check?
Bugga to the caster i just knew it wasnt going to be as easy as that :-)
And i would think you would need the wheels with the weight of the car on them to set it up, bump steer and all that
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
