hey phunky, yeah just saw the ignition dvd tonight, turned out good! and yeah you would love it there , certainly gets the blood pumping!!
hopefully we will try to get back there at the end of the year with the r34, all going okay
pauls twoogle , is one beautiful looking r32 too ! it's a credit to him.
ross, yeah, the oil to water oil coolers are great, we are seeing much lower engine oil temps now! before we were seeing up to 130 degree's!
cheers russ
I was going to bite... but.... what the hell. How could I ever compete with something like your R33 Michael. I can only dream of having the same budget, Power and Grip you do. So laugh away, Laugh at my skyline that can only have realy bad suspension geometry because it is so low. Or maybe I've read widely, spent hours making and developing my own parts to overcome the rollcentre issues and other normaly untuneable aspects of an R33.
So yeh, it is a drift thing that forces the guys at the pointy end of drift to research, make and test stuff to get thier cars to do what they want them to do. Because after all, what happens when drifters get over drift and start to explore other avenues of motorsport???? They get laughed at by knobs who think drifters are just silly kids with way too low cars.
i like drift, !
and our next car will be on the deck, none of the cars i saw in japan (other than ours) was more than about 2/3 inches off the deck.!! awsome
like you say just need to do home owrk on geometry an so fourth.
Most of them don't know/care about suspension geometry, they just stick rediculous spring/shock rates in them and there is no movement, so geometry is irrelevant. Then they have to stick new super soft tyres on for every run in an attempt to mask the suspension issues.
You kicked most of their asses last year with a comparatively miniscule budget, almost zero practise and infamiliarity with the event and the circuit. Don't fall into the copy cat trap, take the technically superior high ground.
Cheers
Gary
Cheers
Gary
gary you are absolutely spot on with those comments, it was the first thing we noticed with there set ups.
Yes! And if it wasn't for silly kids with low cars we wouldn't have parts like this.
I mean really all they are doing is playing make-believe-GT-racer so they want their car to look like GT500 cars.
And tyres are cheap in Japan anyway, so slap in some steel rods, slam it on the ground and slip on some super softs! :(
Oh and if you get a chance run my signature (which i have had for ages) through Google Translate :D
車高の低さは知能の低さ!!!
http://translate.google.com/translate_t?langpair=ja|en
And below is my racing machine... it is slow, but fun
Edited by Laurence
Not since I lost my licence for street drifting unfortunately... >_<
My old car had high rollcentres which is actually quite dangerous, I reckon if the roll centre is under the ground then the car can't roll above the ground! :/
Edited by Laurence
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
