Thanks all! I can't take credit though, my mechanic Sam made it all up and did a great job of it.
Richard, I ended up having the box made up by a friend of 'Craved' on here. Sam ( www.drdrift.com.au ) did all the other work with the hard lines etc
Mate, I would have loved to have had it bought off the shelf, would have saved some headaches! It was all custom built.
I think there may be a market for a pre-fabbed CAMS approved kit like that though
marlin - you need to mate, both the shitters are keeping a knock off 400r and your rival 32 gtst company at the moment!
roy - for tarmac and circuit events the e2 and 3 boxes aren't too bad unless you're dragging. there are a number of beefing up options too that wouldn't break the bank. apparently the boxes get a bad name from guys doing engine swaps into local cars and having the weak local gsr 'box fitted up.
the 4g63 engines go forever, much like sr20s and rb20s etc. for the 4g63 there are plenty of cost effective 2.2 and 2.4 kits too... when i priced a 2.4 rebuild a while back it was only $170 extra to got 2.4 over 2.0 using a factory crank (assuming you'd replace the standard crank).
the pre-e4 diffs in gsr and rs are strong enough for just anything (unlike evo 4 onwards ayc (gsr) units). the gsr spec e1-e3 use an open front centre and are best to be swapped over to ralliart helical front centre found in the rs.
if you wana prepped one i'm considering options on this one and happy to set it up to a spec requested... wont be after big dollars for it either.
boz22n - nup, csc/bmax are grooved that way, zoom in on the veins
there are a few manufacturers doing this, i got confused when fitting mine also, but definately run that way.
Ben are those rotors on back to front or and i looking at it wrong?
The car looks sweet Chris.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
