Haha, why thanks Chris! :P Seems the little 32 has become my "beast" if you know what I mean, we all have an attachment to it now we've been through a bit together.
They creep up on you the silly things. In 5 weeks time i will have had my car for 10years! 8 years ago i would have told you i would have had a 94 LT1 Vette by now...oh well. :D
kinda offtopic-ish...!
but..
http://www.dubaiautodrome.com/general/index.aspx
I told the mrs Im going here when we are in Dubai for our honeymoon :D
most likely will do the audi track tester
http://www.dubaiautodrome.com/general/content.aspx?id=72
Unless Chris (tacker) has an event on and can take me for a lap or 5!
I just got back from Dubai and i was blown away how cool a place it is. Really nice resorts its not too crazy a price and there are cool cars galore.
There is certainly plenty for the Mrs to do to keep herself busy whilst you go do what you have to do at the race track :D
yeah, it will see Lakeside mostly, which is a driver's track, not a horsepower track. I reckon 61's for 5k is achievable. Can't be crazy loud, gotta stay under 95db :)
I didn't think 950 was overtly heavy..... what do you think we should be able to get it to? Have you built one of these pusserz?
I'm guessing this thing must be getting full slicks rather than semis? in that case I think its achieveable. On semis I think you'll need to get at least 160bhp at the wheels to have a realistic chance of 61s in that thing. What sort of power can you get from the supercharger? Or does that 5K budget stretch to a turbo conversion??? do these jiggers have a slippery in them?
Are we running a book on its stock (?) lap times on the 22nd?
I'll be back out there on the 22nd as well. Haven't had a steer for over 3 months! started work on my heap last night fixing the broken intercooler mounts... still have to swap springs around, fit & setup rear radius arms, fit the sump finally, and a few other things. Might even get its first australian wheel alignment! look out!
Well car has made 285rwkw's @ 20psi with a boost leak (injectors not sealing with plenum... farking plenum!), with 11.4 AFR's and only one cam timing change which is very promising... but now water is mixing with oil and we don't know why. I managed 1 lap of Sandown before I had to come in due to some oil spray on the manifold, and checked the dipstick to see a milky surprise.
Head gasket as replaced last week, head was decked and ever since then it's leaked. It's coming out again... :)
A dyno vid here, as well as a few pics from Sandown: http://project180sx.blogspot.com/
G'day Harry! Yeah, the plan is to run slicks on it. It's a 20V, not a charger, and it will stay that way. We still have a couple of k up our sleeve so may slip a Microtech into it at some stage. No LSD standard, but it seems they are fairly readily available on Yahoo.
Look forward to seeing you there again, I've totally worn out my 03G's, and have now got a set of KU36's to go on, really keen to see there lap time v cost v durability compared to the Dunlops.
Mate, if you ever want a hand or a drinkin buddy while you're messing with it, I'm not far away :)
Aaaaagh... mate your due for some good luck!
cheers mate. well if you get bored over the weekend, I'll be under the house working on it! Drinking buddies are always welcome!There'll be beers in the fridge mate. Have you got my number?
Those KU36 are unbeatable for the price, and will be very intersting to see how your times compare to the 03s. Will give me an idea what my Supra would have be capable of. I'd say ~2 sec slower than D03s. But 1/3rd the price! Supra ran 1:00.79 in May on them, but the rears had probably seen better days by then. But only place it would have hurt would be out of Carousell.
NA 20v? I'd suggest a piece of string from brake pedal to left nut to keep corner speeds up? lol I keep telling a mate Rob his 240Z should run 61s at Lakeside - he was over half a second faster than the Supra at QR Sprint track with a dirty old carbied L28. So no reason a 20v can't do it I suppose.
Edited by hrd-hr30
Head gasket as replaced last week, head was decked and ever since then it's leaked. It's coming out again... :P
Ahh ffs!
Why did you swap the gasket anyway?
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
