Really enjoyed viewing this thread and poking around other projects. I will have a 32 GTR one day (next race car build if the wifer lets me).
But at the moment I have to settle for bulding it's nemesis.........
When done I would like to find someone with a racer spec gunmetal 32 to take some professional pics with.
Specs are a little long but here are the main ones.
Engine to 500hp (at Dyno waiting at the moment). E85, T4, solid lifter, ported, dry sumped, pectel, MW cdi.
Hollinger H6S, twin plate AP 7 1/4.
8.8" Mustang plated irs diff in modified rear cradle with camber/caster adjustment and adjustable bladed arb.
Adjustable front tca and top mounts.
6 pot 355mm brakes front, 4 pot 330mm brakes rear - adjustable pedal box.
Motec dash, pdm.
As much carbon as I can get my hands on.
17" and 18" centrelock wheels.
That's awesome Lincoln!
Where are you based mate?
Thanks am in Melbourne.
Do the modern day turbos on the seirra reduce the lag much?
Still have a old school turbo for strength and reliability - have a maram 247 shaft and wheel. Have upped the compression and i'm guessing more suitable adavance with the e85 but will still be lucky to see full boost (30psi) before 3500rpm. Good things done these days with twinscroll and may go there after as the standard cossie exhaust manifold was designed for it.
You a Targa nut? Man I love Tassie.
Thanks all.
Man I love the detail in this, all the little things that people like me always want to do, such as the carbon bonnet pin surrounds and mirror mounts etc, but never happens, your car has it all, so neat.
and dont sneeze at 30psi by 3500rpm most of us wish could get that in skylines.
Hell my stock turbo soarer wouldnt get that lol.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
