I'm not married, but will gladly get hitched if it means handing her over to you will solidify me a steer in the Rad :)
:cool::blink:
Me either! :devil:
Haha I recall you also offering me a go in your car some time ago if ever I was in QLD, so the offer is back at ya mate ;)
Im up for car swapping too Dane! I mean, who wouldnt want to drive the red wiggles car!
Haha I really should have a key party, I think I'd take home the prettiest girl in the room... if only it had a key.
Yoki is realeasing a true man's tyre soon, 295 :devil:
That's my aim!
Who needs geometry when you just have an excess of tyre! :blink:
WOW! That's insane. Prob be hard to make a 295 work on a car that light without the aero of Berry's 34.
Why spacers? Do the 10.5s hit the suspension, or are you two whacky kids just got track on the brain?
Yeah my 18x9 +22 RS's nearly hit the suspention up front with 235 tyres! I'm amazed that you fitted your 19's on your 32 Ben? Did you put em on the front or back?
You got it Dane :devil: Feel free to bring some of your hot women too you big hunk of spunk! :cool::blink:
Russ, I only put one on the front..... farkin hectik. iPhones take awesome pics....
Front, NO spacer, with a 285/30 tyre;
Have you trial fitted rear yet?
Edited by Marlin
LOL, yeah maybe, but I plan to make the body actually go over the wheel/tyre so them they'll hate me again :blink:
Least it will go round corners then.
but needs a set of wheels like this to go with the truck turbo :devil:
Brus aren't you supposed to wedge a credit card between the tyre and the bodywork?
this is probably as bad a place as any to ask - what do people know about 5Zigen wheels? up to the job of bouncing off kerbs?
We should talk Russ, see eachother through this :P
I'm thinking +15 with a 20mm spacer.... am I being silly do you think?
Where can we buy SLR5000 type flares for these things?
Yep I was thinking the same. Perhaps 15mm spacer if possible.. I was hopeing to get them under pumped GTR guards front and rear... Don't really like bolt on.
My next step is to put some 265/35/18's on my SL's and trial spacers. 20mm is most likely. No time atm though.
If it's a silly idea then that makes 2 of us haha. Check out my fb photo's when I trial fitted with 25mm spacer (no tyre)
yay this is my kind of topic.
get yourselfs a copy of the latest HPI. it has a s15 time attack car from J pan that was featured on speed hunters a while back. they just used the stock guards but spaced them out about 50mm with some bracketts. instant wide body. as always it could have been done nicer.
also not sure if either of you guys are running them but r33 lower contol arms will push track out moreso.
if you get much wider than a 10inch at +15 you will be getting scrubbing on the fire wall and chassis rail. i have 10 +15 on the front of my car with r33 lca and modified lock for drifty drifts and there is rub marks every where. i know you guys dont need ooooober lock but its worth considering.
oh and 10 +15 fits a gtr guard perfect so you can go a bit further and roll the guards.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
