From what I've read, it's luck of the draw. Some have had the car for years without a problem others have bought brand new motors and have had probs again. It's definately not a problem with EVERY car.
My opinion is that every car has it's issues. The good thing with my experience with Nissan's is that the issues are generally not thousand dollar issues, and more little annoying things.
In the end you get what you pay for. People sometimes forget that the V35 for what it is, is a very very cheap car. Similar performance, similar looks, similar equipment in most other cars, and you'll be laying out $100k.
Iam in the process of purchasing a V35 from Japan, do they come with factroy keyless entry ? if so a people has mentioned that the keys has stopped working is that the remote ? also people mentioned what happens you cant get a car if your keys has stopped working isnt there a hole to insert your keys into ?
yes there's keyless entry
mine has worked 100% fine every time so far (about 2-3 months)
there is a key hole if it doesn't work, but mine came with 2 keys (with remotes) and the valet key so its not like you're going to be left stranded you will have a backup
don'ts worry mate - the V35 is a treat of a car!
Yep, I own it for more than 1 years now. when I purchased, it is alread more than 34000KM. I believe it is higher than anyone else here. but I had never have any problem. Trouble free and stylish car. I am pretty happy with it so far.
i also got two original keys with remote.i also got a third marone/red coloured key.
is this the valet key or the master with which to cut new ones from.?
i only ask as my old honda had a red master key ,which if used to start the car it would render the car undriveable!!!
red key is the valet key
it opens the doors and starts the car only, ie if you're leaving the car with someone else
has no alarm function, won't unlock the glovebox, and in other cars that have a boot key hole it won't unlock the boot..
i use it when i take the car to the carwash
Hi, this is one for the V35 6MT guys, have any of you guys had problems with the clutch being noisey or having clutch chatter or vibrations through the clutch pedal? I've read on the G35 forums that a lot of the 6MT guys have this clutch noise or chatter problem.
cheers
  • 3 months later...
My drivers side window doesnt go up sometimes! I can hear a relay clicking under the switch box but thats about it. Then it works again sometime later.
ANNOYING!
JK
Yes, this problem is very annoying. However, I can confirm that the 'tap' works. My sparky told me it happens in some cars and may eventually need to have the motor replaced, or it could be that the window gets dirty and causes it to stick. I have noticed that my windows have been dirty evertime it happens - may just be coincidence?????
To open or close...... simultaneously, hold the relevent window switch (up or down) and give the door a 'fonzie' on the inside door panel - has worked everytime for me so far when I tap the top of the door panel.
For those who are too young to know who fonzie is, forgive this old bastard and, just 'give the door a slight thump with your palm' :banana:
Cheers,
Vic
My v35 has just clicked over 50 000km, bought it a week ago, so far no major problems however fule consumption is up around the 14l/100km with mostly highway driving. This tank looks like the consumption is getting worse. Also noticed that the car seems to be sluggish sometimes with seems to be coinciding with when the car has less than 1/4 tank of fule left. Im hoping to get my hands on a scanner to take a looksy to see if i can see any problems with it.
Other problem is the light between the sunvisors some times dosent work on one side, but a good tap seems to fix it.
Ill be sure to keep you guys posted whith any other problems i come accross.
  • 3 weeks later...
Hmm just wondering with this clicking noise.
Is it different to the clicking noise you get when the rear pads are really low ?
Yep, it's a known fault on the rear axle. Usually on the right side of the car.
have u guys had any luck getting this fixed? if so how much did it cost u? I mean it's no big issue, js make the car sound cheap when u have lose metal sound clicking everytime u change gear...
I had the captive bolt that holds the shifter fall off. I replaced it all with a short shifter in about 30mins. The shift distance is about half what it used to be. Best $100 I ever spent.
Hey mate,
which kit did you use?
There's a few discussions in the US about certain kits being terrible.
  • 4 weeks later...
just a question regarding the engine. say if you were to Twin turbo it, would that bring it close to the new VQ38DETT in the R35GTR? as the difference is only .3L
Just weighing up the option that's all!
in terms of power? i believe a TT 350GT can generate about 400-500hp depending on the kit. but performance wise it will be nowhere as good as the GTR...
you can give it a great bit of performance with a TT or S/C kit, make no mistake (have a good read of g35driver.com - there is a whole forced induction section)
but the VR38DETT in the GTR is a completely diferent engine, with many parts that are unique and make it as good as it is. plus the car is a whole different beast - AWD, bilstein suspension, etc etc
you can never make a GTR out of a V35
but if you have realistic expectations, you can make one very fast and awesome looking V35 that is good in its own right!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
