Ive got a few bolt on mods to my R33 and its gettting very bad Fuel economy,
Im only getting 280km per tank on 98 octane, and to top it off its running like crap cos its not tuned for the new setup.
Question I have is how far can I expect to go after I get the new 2835 fitted and tuned at around 260rwkw or so.
Highway and around town figures if ya now what you get???? Or litres per 100 would be good.
Mine is getting 14L/100kms on flat road at 110kmph............
Dave
https://www.sau.com.au/forums/topic/177634-how-far-can-you-go/
  • Replies 42
That's terrible fuel economy! I get about 400ks to a tank these days, but most people will say it all depends on how heavy your foot is!! Driving over to Perth from Qld I got about 580ks to my best tank, but my lowest has been just over 300. (Had 2 cruises in 2 nights hehe)
im lucky to see 300kms to a tank....!
highway i reckon i could just squeeze 400 out of a tank but i dont do that much highway... and i LOVE boost!
Try Resetting your ECU by disconnecting it and leaving it overnight... the ECU will self learn and possibly pick up your mods a touch better.... hence better economy.....
easier and quicker way is to take of ur negative terminal on the battery then hold down the brake peddle for about 1min (this just drains all remaining power out of the system) then put the negitive terminal back on, turn the car on and let it run for about 2mins on idle (this is auto adjust it as far as it can with stock limitations). This isnt gonna solve ur problem but it should help
Quigga
it really annoys me when people say "i got xxxkms to a tank". how many litres did you use? i can get an extra 50kms out of a tank by driving round for ages with the fuel light on. it doesn't mean i got any better fuel economy.
turbo dave: 14L/100km is pretty bad for highway driving. i got 10L/100km out of mine, but it was stock turbo. but then i would get 17L/100km round town.
have you tried changing your o2 sensor to see if that helps?
Im looking forward to fitting my 2835 to my RB20!
Highway driving is gonna be awesome! Well thats how im imagining it..... Since its gonna be a alot laggier than stock... So hopefully it will sit off boost @ 110 and be off boost in the city driving.
But thats an RB20 and yours is a 25.... Id be saying you could easily achieve more from that turbo with a RB25.... Im aiming for 260 with my RB20
I used to average 300km in my 32 IF i was lucky... Oddly enough the faster i went the less it would use..... Eg. 290km trip @ 110 had to refuel, same trip back @ 160km/h (1am in the morning) most of the way i still had almost 1/4 tank left
Edited by MADGT4
It really really depends on how heavy your foot is.
I was born with a lead right foot, so my car hardly ever sees over 300 to about 45 L.
With the bigger turbo, driving around town, it should be harder to get on boost, so if you're trying to drive economically, it should use less petrol. The stock turbo goes on boost at the lightest touch of throttle, or up the slightest hill.
But on the other hand, the bigger turbo, plus fuel requirements means that when you give it some, it'll use more fuel, because it makes more power.
So in essence.... It depends on how you drive it
I get 10L/100 always. Aftermarket map sensor based ecu.
Runs less on the F3 everyday to work.. but more round town... always fill up around the same time.. always 40-45 litres
Although might change when I pick it up this week... was on 263rwkw... is now on 300+rwkw... :)
*edit* I also tend to have a heavy foot.. occasionally.... maybe... :thumbsup:
well, i once drove my old manual 1.3L 16V Charade for 180km around the sydney metro area after the fuel guage touched the 'E' mark. it sputtered as i was driving towards a servo, i pulled in, and it stopped just as i pulled up next to a bowser, and wouldn't start again until i got fuel :thumbsup:
don't know exactly what economy that meant for the full tank, but it was in the 7L/100km zone
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
