edit.
hit the wall and continued on almost the whole way round the track till it caught on fire?!
determied to get a lap in...muppet.
it actually did 4 laps after hitting the wall and came close to it on a few other occasions. The flames flared pu when they were pulling off the track at the end of the demonstration
