Spotted another Veyron today, baby blue on silver. Also more ferrari's than you can poke a stick at, then there was the Conti's, porches and SLR Merc's. Anyone care to guess which city/Kingdom i am in at the moment???
I'll put some pic's up when i get them off the camera.
Jeff we timed 2 laps - did a 1.50.0 and a 1.50.2. Apparently Christian Murchisan did a high 1.48 earlier in the week.
Not bad for a production car on street rubber (Pirelli P Zero). I sure as hell was impressed. Not to mention I did 40 laps in 2hrs and the car was still perfect at the end (brakes fine, water 90degs and oil 100degs)
FYI Christian did some hot laps in the RS4 which we timed at 1.55.2 - so the R8 is considerably quicker.
That's awesome isn't it? This newer generation of cars are really eclipsing the previous generation.
saw a black c63.. plates were 19 or 16
in camberwell it tore past me.. that engine actually made me semi errect. was good to say someone buying one of those n using that car to its potential.
Ah... nope. There's a few now.
You should retract that statement before you are forced to eat your (vegetarian) hat...
http://www.skylinesaustralia.com/forums/in...=178021&hl=
LOL @ Vegetarian Hat :laughing-smiley-014:
Seems my eye for one colour Veyron's let me down this time though :wave:
it's my boss, the plates are 19, i think there for sale with all his other plates
I feel so depressed again, have seen so many Maseratis, a few 599 Ferraris or a few of them may have been 612s?!?! Saw a shitty R35 that was going farking fast and loudly and proudly down the road. A few M6s...like i said, its depressing looking at all these big dollar cars being driven by blokes younger then me, And very few of them are ex-pats :wave:
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
