wow, thats impressive, was it a HK500, did you get pics ???
Yeah HK500, I was so happy the guy was giving me a quick look pics didn't even cross my mind until later ;)
Dark silver car with red interior, faultless... gorgeous in the flesh
spotted a black Chev Camaro soft top turning onto westal road out of a bathroom factory after work today
same camaro as Bumble Bee Transformers
hsv factory is on westal road, intersection with center and westal.
Probably taking the car on a test drive.
Have seen plenty of w427's flying past recustoms :)
Hahahahaa! Love the wing. the funny thing it's probably stock!!! Nice semi slicks to... I wonder whats under the bonnet.
The wing is stock mate, it's a special car: http://en.wikipedia.org/wiki/BMW_E9
Nice spot Greg
the csl batmobile was awesome to spot! something very cool about spotting old cars like that in mint condition, much more interesting to me than the late model red and yellow super cars......
anyway,
this is my favourite "new" (late model) car at the moment!
although if i was feeling picky I would have to say silver is the colour to get!
excuse the glare it was very sunny...
Saw a Mustang down heartherton road, drove with it from clayton road to noble park.
sounds nice, the same fast back model as 'Elanor' 67 i think it is .
really nice metalic blue with cromw details and rear lead lights that blinded me even in todays sunlight.
oh yeah came factory with left hand driving porno mo, tattoo bearing, middle age man.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
