  • Replies 47
Why does it not have the centre MFD?
it's hard to make out in the vids, but if it's the car I think it is when I saw it in japan it had a full custom dash hence no MFD. but I could be wrong, the dash does like a bit R33 GTR in shape. still fairly sure it's the NAMS 34. but again, it's hard to say with 100% certainty from just a blury interior.
BTW, the red car you linked, and the silver one is not the same car. the red one is apparently a customers car that has been exported.
yeah there are a few hard core cars getting around but not many with the same kind of single focus as the japanese time attack cars.
UAS 300ZX
Racepace GTR
Giants GTR
ex-Whites targa 34 GTR
plenty more I can't remember.
UAS 300ZX
Racepace GTR
Giants GTR
Yeap,
I've seen Racepace GTR at Sandown, also my fav of all time workshop.
I've heard, read about UAS ZX, pretty hardcore as well but it runs on SLICK, full time attack car but none of these workshops are really into TIME ATTACK theme if you know what i meant, the Jap way.
We'd love to see all these cars get together and flog the crap out of Sandown to see who's the fastest, just like Tsukuba time attack that BMI organise every now and then, would be MAD.
I blame google. Google and global warming. :(
haha killer car and a nice bloke to boot, spent some time (and alot of cash) at his workshop/night bar whilst in osaka with Hiko from signal. He is a full-on AE86 freak too. This car has a BIG T88 trust turbo and was one of the fastest GTR's in time attack for some time.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
