Went down to visit my car today @ Racepace and things are looking quite good.
Few other SAU members down there too so my little secret is out as the car is basically finished for the most part after 18months and a lot of weekends
There are loads more pics in my gallery of various stages and stuff if people havent already seen them.
Cant wait to drive the thing, should be a load of fun im predicting!
https://www.sau.com.au/forums/topic/180414-finally/
  • Replies 47
It was orange, but it just didnt fit with the engine bay respray ;)
I should have done that first, and THEN the covers etc, lesson learnt in colour coding there!
Ye, last stage really Al. Andrew is going to do the wiring during the week on it, then run the motor in and go clear the EPA i've had on the car for 18months now and i can register the car, and that should be done within a month pending appointment avaliability and shit.
Exterior is the same, still pretty rough and still that 1/4 panel ding lol.
Ill respray all of that at a later date as i have a lot of things i wanna do and change (wheels and so on).
https://www.sau.com.au/forums/topic/180414-finally/#findComment-3281638
It was orange, but it just didnt fit with the engine bay respray :worship:
Great, can't wait to see that beast on the road again. We need our club esky back ;)
https://www.sau.com.au/forums/topic/180414-finally/#findComment-3281845
I must say this was the first time I had officially seen a car with Ash's name against it. The orange definately didnt go but this colour looks ace.
Well done on keeping the light at the end of the tunnel and look forward to seeing the finished project. ;)
https://www.sau.com.au/forums/topic/180414-finally/#findComment-3281996
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
