Simple question;
Is there such a thing as too much castor? If you can get up into the 11-13 range is it worth it? Can you run significantly less camber as a result or is it pretty negligible once you get past a certain point? Does too much castor bugger up the inside wheel geometry significantly after a certain point when it's turned?
No drive shaft angle issues, no scrubbing on the front of the guard issues. I have none of them.
I have installed a set of GTR adjustable upper arms in a gtst and it has shifted the top outer mount back a good 15-20mm. So bulk castor when combined with the 8 degrees i had to begin with.
cheers
Dave
edit: I can't spell
Edited by BHDave
https://www.sau.com.au/forums/topic/181669-can-you-have-too-much-castor/
again i stand to be corrected but your upper control arm governs your camber not castor. Surely with 13 degrees castor you would struggle to turn it i think
I have these upper arms. Note that the position of the mounts is parallel as opposed to staggered with the out side forward on a stock arm. If you rotate one end the castor is either increased by a ridiculous amount over stock or reduced by a small amount depending on which way you fit it (noting that the inner and outer mount lengths are different so there are only 2 ways it can go in). left straight i'd say it gains atleast 2 degrees, haven't got it aligned yet to confirm the angle. But i can increase the castor further by rotating the outer end. Installed pic Hopefully this link works.
By winding them in and out it effects camber, so it does both, though i'm interested in castor at this stage.
Booster, definately installed right. I don't know if the stock gtr and gtst upper arms are different as i have never looked at a stock gtr upper arm beside a gtst one. During install i had the stock arm sitting on the ground next to the aftermarket one and as noted above it was either lose castor or gain castor. I went for gain because i've always understood more is better, but how much more?
I have tried various caster settings from 4.5 degrees to 13. At 13 I had rubbing issues and settled on 8 or 9 I think. For the street I find this perfect. When it was at 13 I found it annoying to drive as it takes more effort to go off centre and strongly wants to return to centre when you are going around a bend. That said, turn in was brilliant.
Speaking to John at UAS about the slot car, he said he went up as high as 13 but settled on 11.
to be honest too much caster means you end up sacrificing camber. in the begining I loved caster and yeah it's great but it's not substitue for neg camber. in the GTR with 255 fronts I can't get more than about 8 degrees neg caster as the front of the tyre is just about touching the guard liner. Also it limits how much camber you can run as of course the arms are pulling against each other to some degree. I would say get as much caster as you can until it begins to limit the static camber you have. if you want some track work I reckon you want the camber up around 3+ of neg.
I did the same thing when I got those arms, the problem with mine was, as they're staggered arms, I put them in the wrong way and it gave heaps of castor and bugger all camber. When I had the arms maxed out (short as possible), the wheel aligning machine read about 16deg castor and about 1.5deg camber, so really sacrificed static camber.
I'm fairly sure that GTR and GTS-t arms are the same though, maybe one's a bit shorter than the other from stock, but I'm fairly sure the offset of the arms is the same for both. My adjustable GTR arms seemed to be pretty damn similar to my stock GTS-t ones anyway.
Edited by salad
There are two completely different circumstances where castor will & will not help you.
1. You are one of those drift type people. In which case loads of castor is good. It gives you strong self aligning torque (for when you let go of the wheel) & more -ve camber at large amounts of lock. All of which is good.
2. You have a track car, or atleast want to do hillclimbs/club days etc. In this case caster is much less important & certainly not at the expense of camber. Simply put more castor gives you more camber when you turn the wheel. However if the car if handling well you wont use much more than about a quarter of a turn of steering lock. The amount of extra -ve camber castor generates at these angles is negligible - particularly is you have an R32 which only has anout 3 degrees castor to begin with.
This is the answer to the second question i hadn't gotten around to asking yet :( Obviously the caster is going to have minimal effect at small steering angles, at which point the camber has to be there to work the tyres properly. I would assume increasing both camber and caster would see the dynamic camber way too high on slow tight corners too.
Thanks for the input everyone.
Quick question for salad; When you put the arms back in the right way what did your camber increase to?
Edited by BHDave
when I had those arms in the GTR (installed the correct way) I could only get arond 2 and a half degrees neg as I had so much castor. with my new noltec arms I can get about 3 and a half.
I would just like to say Dave, I believe that your question is not stupid, and very valid.
So I guess the question now is, whats the equlibrium point? What is the best match of castor to static camber? (as a general rule of thumb)
I just did my alignment today and my caster reading is 5.4 deg for both sides. Camber is 2.1 deg front & rear. Currenly all my arm are adjustable pillow ball type for both camber & caster all round. The handling is so far acceptable but i wish to have a setting for canyon or back road type of driving with slight understeer since i still haven't learn the art of drifting.
Appreciate some feedback...Cheers!
Just a quick update and more insights into what happens to the front end geometry of a skyline when you change things around.
So i swapped the arms around this morning so that they are staggered forward again. I also double checked and yep, the outer on the arms sits 5mm further forward than stock so i will have lost caster.
But i did gain camber, somehwere in the order of -.5-1 degree by eye
And here's the funny part, as it rotated the upright so much the height of the car dropped by about 10mm due to strut alignment changes i guess. I had to wind the coilovers back up. bonus 10mm extra travel before i hit the bump stops :)
Edited by BHDave
yes you can it makes the car very unstable mid corner. basicly just a prick to drive fast. i pulled mine back to 7 degrees. (was 8.5-9) much better now
Do you reckon i should adjust my caster to 7 deg since i find the steering is kinda light on high speed corner. Mine is now at 5.34 deg with 2.1 camber.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
