seems alot of ppl are having dramas with these manifolds, i put mine on about year and half ago... took few days, didnt even use new gaskets and never even got it shaved. hasnt leaked and still going strong lol
even came with every bolt i needed to bolt it all on + vacum fittings.
keep at it should all work out in the end.
  • 3 weeks later...
Hi Zebra , any chance of a pic of where the bleed valve is . I'm interested to know if a mount could be fabbed to fit the knock off manifold to mount the bleed valve conveniently .
I was looking at one on an R33 yesterday and I'm also interested to see if the plenum inlet could be flange modified to take the std TB and so leave room for the std washer tank .
Cheers A .
Edited by discopotato03
Anyone else done the install without blocking up the pipe coming out of the thermostat housing?
Look two pages back :)
http://www.skylinesaustralia.com/forums/in...t&p=4333536
Edited by WilYawn
Cheers A .
there are adapaters you can buy for about $90 to bolt on the factory TB.
also if you run a 90 degree silicon bend of the TB and down thru your usual intercooler hole. you can retain your washer bottle..
its all so very simple.
if you look around for the greddy instructions in pdf, you will see they remove absolutely everything water hose wise and run a hose from the nipple at the back on the heater hose to the nipple at the front near the thermostat
pretty easy
  • 3 weeks later...
I bought a greddy style plenum KIT from vulture motorsport. Cost me $565 deliviered. It also came with a throttle body adapter and all the other shit you need to do this. Was a prick of a job. Im not a mechanic but like to do my own work so I had a crack at it. I Was pretty much stumped with it half on until I found this thread. Awesome write up :P
I run a 90 deg silicone bend straight off the throttle body. I had to cut the existing hole a bit more to make it work. Got a new lenth of straight intercooler pipe and had a vaccum nipple for something on the Power fc and the AAC line fitting welded in. Because the washer bottle now didnt fit I took it to the plastice welders. They chopped the bottle in half, right beside the internal pumps and sealed it back up. It half the capacity of stock now but at least it isn't a defect and you still have enough water to wash the windescreen.
The tosser who owned my car before me cut up the stock plenum and put the throttle body to the front greddy wank style. It hurt tuning and I have NFI why it was done. Ill put up some before and after shots....
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
