Hi Folks
Ive done a bit of a search but couldnt find an answer so if there is one out there and ive missed it, plz dont shoot
my question is, I have an r32 gtr - I would like to have dual exhausts from the turbo back, however I'm not sure how this will affect the o2 sensor setup...
There's a reason they merge the pipes, if you really want to have twin exhausts do it like they do on V8s and use a cross over pipe, this way you use the exhaust system more effectively increasing flow and also avoiding this problem.
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307146
cool thanks for the advice, i think thats the easiest thing to do rather than messing around with the o2 sensors
-D
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307324
Hi Folks
From what I understand there are 2 o2 sensors for the 'before cat' and 'after cat' positions, my concern is if one could put a dual setup on a gtr and use either a single pipe as an enrichment template, OR if i could add another 2 o2 sensors and then aggregate and halve the values produced to nistune
Im not a mechanic and I really dont know how this all works, however I just want to know if its possible to run dual pipes, and how I may go about it
Thanks
-D
Its simple, gtr's have 2 o2 sensors, one for each turbo
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307343
No one actually picked up on this... There is only pre-cat O2 sensors on a GTR, the post cat sensor is an EGT for sensing when the cat is too hot only.
Running twin pipes full length will be no problem at all, just disconnect the post cat egt (plugged in under passenger seat then through floor).
I for one would be curious how a full twin system would sound :D
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307407
correctamondo there is two o2 sensors on a gtr in each dump pipe and a egt sensor near the cat pretty much does Jack all tho so don't worry about it. But have good o2 or new ones to get good closed loop in nistune
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307429
beat me to it. yeah the 02 sensors are in the dump pipe, so you could run a twin system with twin cat's if you wanted. might struggle for space though. you'd probably only want to run a twin 2.5" system or maybe 2.75" system, because unless you are running some big power that is all you'll need (a twin 2.5" system will have a bigger volume than a single 3" system).
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307432
two 2.5 catco cats would work nice on a twin system but unless you are wanting to push a 1000+ hp a good 3 inch or 3 1/4 will do the job.
Plus you can buy them off the shelf and runing a custom twin system would be a right pain.
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307451
Hi guys,
Ive read through this post but i havent really come accross with an answer so i thought ill just ask!
I know that to run nistune in a r33 you'll either need a r32 ecu or a 300 ecu but does anyone know if nistune are planning to make a board thats compatible with the standard r33 ecu considering most the other models can run nistune standard?
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5307711
Will sound the same unless you move the pipes to different sides of the car or you are standing directly behind it.
Personally I would still use a cross over pipe, reasoning being is only 1 cylinder is firing at once, if you have twin separate pipes then the single pulse is only going out one pipe, if you have a cross over pipe then its going out both pipes.
Obviously with a turbo and the compression of the exhaust gases the pulses basically merge into a constant flow, but there are still some gains to be had by using a cross over pipe.
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5308848
  • 1 month later...
Hey guys,
I have got a R33 GTS4 with an rb25det. Took the car down to a tuner today only to call me back up saying he cannot place the Z32 nistuned ecu in it due to it being AWD. How can I get past this as I really don't want to give up my midrange power by losing my VCT?
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5374955
how does the engine computer affect the AWD in the transmission on these? With Z32 ECUs you still have VCT but with R32 ECUs you need an external VCT controller (based from RPM signal)
I was planning at one stage but the extra work with complete new board design, prototyping etc, new firmware and very difficult installation made it a difficult one to approach
Coupled with Z32/R32 ECUs now provided as viable alternatives means the effort to make boards for these is no longer viable (especially with my current work load)
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5375309
Hey guys,
They finally worked it out and have put in a z32 ecu after downloading a new image. Just got it done yesterday and have noticed my slip light randomly stays on until I turn the car off. I haven't tested it if its running RWD as do not want to do any harm.
This seems to be a common problem with some GTRs however I know this is caused by nistune or the tuner themselves. Anyone got any clues?
Apart from this light coming on every now and then my car is running better than I ever expected, love Nistune :P.
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5390404
Apart from this light coming on every now and then my car is running better than I ever expected, love Nistune :P .
i had mine dynoed with a z32 then with the r32 and lost no midrange at all?
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5390602
Hi guys,
To the best of my knwledge:
No!
The Z32 ECU is supposed to run alright so Nistune (Matt) won't be doing this board ..
R32 ECU = No Variable Cam Timing!
Z32 ECU = Variable Cam Timing Works
Edited by Torques
https://www.sau.com.au/forums/topic/181930-nistune/page/14/#findComment-5391720
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
