  • Replies 45
Must be a higher turnover for RB26 - cause surely the rods arent THAT much different
well- they are longer
but not $40 worth of metal longer each :)
mebe ppl just think RB30 rods are awesome and should just be left as is :D
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3319479
doubt it- the extra ~11mm of stroke would cancel out the extra rod length. and the piston speed would be slower on an RB26 at the same revs anyway
And the rod ~31mm longer. That's more than an inch. Tell me that an extra inch isn't all that handy?
It's all about the angles. . The extra crank throw is halved, so it's not the full amount of the extra stroke (11.23) But you do get the full rod length difference (30.9). And if you needed to spin the 30 to the same revs you'll be flowing alot more. Stroke:rod is a bit better at 1.79 on the 30, 1.64 on the 26.
Haha and at the end of the day the angle works out to be a bit more than 1 degree.
But isn't all this rubbish in the RB30 thread?
ps I think the rods are more expensive on the 30 as they are more popular, and he isn't moving any of the 26 stock at all. Liquidation time!
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3321557
but he's not using a 26 crank in a 30 block- so it's no different to a normal RB30
since when do economies of scale make the more popular parts more expensive? Ferraris are popular and expensive, but only coz they don't make many of 'em. i reckon it's just because people use expensive aftermarket rods in 30's less often.
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3322808
I always knew that the angle of the dangle was proportional to the lust of the thrust.
Dammit I thought it was the throb of the knob. No wonder I've been getting it wrong.
Steve: no probs. I have a fair amount of hoarder's rubbish that I'll list up as freebies, just need to get the motivation to list it all.
lol!
Yeah thats cool, seeing as you're so close let me know and ill come take your hoarders rubbish an turn it onto my hoarders rubbish :) But yeah, let me know what you have lying around :P
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3323222
lol!
Yeah thats cool, seeing as you're so close let me know and ill come take your hoarders rubbish an turn it onto my hoarders rubbish :worship: But yeah, let me know what you have lying around :(
Hmmm I wouldnt mind getting in on this..
What sort of hoarders rubbish are we talking about Dough Boy?? :D
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3324102
Heya, it's mainly odds and ends from RB motors. Some of it might be worth a couple of dollars, some of it not really. Have got sumps, intakes, exh manifolds, wiring looms, CPUs, oil block plates, injectors, pipework, turbos, dry sump bits, brakes, rear end parts, rods etc. One of those things I keep meaning to post up but never get around to. And at the moment everything is piled up ontop of each other in an effort to give me space to work on my car, so access is a bit of a bitch.
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3324175
i'm in need of a stock RB26 sump if you have one doughy? not after a freebie though will happily stump up some cash if you've got one.
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3324250
Have got a GTS-4 one and a 26 one. Was meant to be checking the ratio on the GTS-4 one for someone (I forget, yes I am lazy but I still remember I need to do that one day). I'll PM you midweek and let you know what ratios they are.
I admit that it's not really rubbish, just stuff that has no interest for me anymore. Not when there are 3 V8's sitting here, with 2 over 1500hp....
https://www.sau.com.au/forums/topic/182768-rb30/page/2/#findComment-3324288
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
