Regular Vs Premium
73 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Always 95ron+ If you use regular, try not to boost your car. The minimum you should use is 95 octane fuel.
Edit: I remembered you have a NA Skyline.
Edited by adam-__-
seeing as my line was designed to run on 100RON, i'm not gonna be a tight ass and run it on 91 or 95RON. it's only a few dollars extra for decent fuel ffs
bp ultimate or vpower racing :)
Edited by into oblivion
I just want to add that running your car on 91 octane fuel could give you less km from a tank than if you're running on 98. The money you save by running on 91 octane fuel is not all that much if anything at all when you're filling up your tank more.
In other words, you could get 300km out of a tank of 91 octane fuel, but you could get 350km out of a tank of 98 octane. Your engine is tuned to 100 octane fuel.
Edited by adam-__-
The BP up here (karratha) dosnt sell ultimate 98 they only have premium. Premium is the highest octane we get :yes: so i might have to get my car tuned to that. . . . or add tollune (spelling) every time
These cars were only ever built for the local japanese market. Japan as far as I know isn't aware of fuel lower than at least 95RON so none of their cars are made to run on 91RON fuel. Especially skylines and related cars. I believe japanese fuel is above 100RON so I'd recommend 98 as its the closest you can get in many parts of australia. Some states have 100RON (lucky ppl) although that comes at a higher price too. 98 is quite safe.
Depending on how your car is tuned, you may have trouble even with 95RON - i know my stagea pings a little on it. Its BP Ultimate98 for my stagea. Have tried shell vpower but wasn't as happy with it. Each to their own. :yes:
Offtopic a little - I often wonder how many people who buy these new hot hatches and other new aussie-delivered cars realise that they need to run on 95RON or higher??
Many of us are only vaguely aware that 91RON fuel exists, and yet most people out there are unaware there is anything OTHER than 91RON... :)
It doesn't matter who sells it, if its cheap, people will put it in their cars.
BP ultimate in my GTR, although i run boost 98 in my civic.. and it sure feels real peaky lol and gets more km per tank, so i might try run that in the GTR and see what i get on dyno to see if theres any difference
I only ever run BP Ultimate. I've found it to be the best fuel for me.. Never really tried Shell optimax though.
Previous owner used to use Caltex Vortex - he filled up my car with it prior to handing it over, car would ping occasionally at higher revs. BP Ultimate has not done this.
Seriously, how much do you really save filling up with cheaper fuel.... a few dollars. Then take into account less k's from the tank of cheaper fuel..... if you need that $5 you saved that badly, maybe you should buy another car.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
