Supercar Spotted Thread
Primordial
 Share
this was at a Holden dealership.
that was in artarmon wasn't it Andrew?
its not actually a Holden dealership, its some sort of supercar dealership in the same building, I've also seen some lotuses and a TVR in there....
my mate recons he saw a bugati veyron the other day..
i don't know if its true or not so i kept my mouth shut so i didn't look like an idiot
are these even allowed in the country yet
Its certainly no supercar, but I spotted a 2008 model HSV Grange yesterday...
The most interesting thing about it was the number plates: LS7 HSV :rolleyes:
LS7 is the 7.0L V8 from the Z06 isnt it!? Is this guy lying or is this a test mule maybe?
Phwoaah.. I didnt know they had the CCR in oz yet!
Good spot (even if by proxy! :))
ok sweet thanx 4 dat.. plus they didnt even have one at the motor show so i found it quite strange
Yeah I wasnt surprised that the Veyron wasnt there... 99% of all cars displayed are there for one reason - to be sold! There is no reason to go to the expense to display a Veyron if there is no plan to sell the car in australia (unfortunately for us! :w00t:).
The Sydney "International" Motor Show isnt really a hugely important show in the scheme of things anyway. The Lamborghini Reventon was going to be displayed this year, but they decided not to bring it here JUST IN CASE something went wrong with shipping and they werent able to get the car back in time for the Tokyo Motor Show... it shows how important we are! :D
Yeah, there was a guy on the news a while ago that owned one... and some shit happen with a bank, and the bank wanted to take it off him, so he hid it in some shed somewhere under some shit :D
I'm fairly sure these are unregisterable...
Spotted a whole bunch of Aston Martins, Porsches and various other luxo-mobiles just then, as I went with my old man to Trivett to pick up a car. All of Trivett's service centres are grouped together in Parra/Rosehill. Didn't see Samuel (WTF33R)'s car tho...
Also saw an AMG SLK about 10 minutes later - not sure if it was an SLK55 or 63 or what, but it sounded HOT!!!
 Share
    • Did some maintenance on the MX5, did the engine oil and filter which was uneventful, then I drained the coolant to put in the new reservoir and a thermostat, reservoir took 5 minutes  The thermostat, well that took.........3 bloody hours, what a job, the issue was the 3 bolts holding it on, one was easy, 2 were hidden and required a few 1/4 drive extensions, 1 more than I had, and a 1/4 swivel, which I also didn't have, and a good amount of playing contortionist  Getting the 2 unseen bolts back on was a time consuming nervous nightmare, as I couldn't see where they went there was alot of stabbing and hoping for the best, trying to line up a 8 mm bolt straight, which you cannot actually see or get a hand in there, with a 1/4 swivel in the mix was a nightmare Anyways, it's done now, all burped out, and run up to temp a few times, happily no leaks thank Jebus After the thermostat fiasco I decided I need a few mental health days away from tools before doing the rest of the servicing on it As for the Dunnydoore, it had the aircon regassed and it has a clean bill of health, thinking about taking it out on Monday for a cruise down the coast to look at some houses if weather permits
    • In other important race car news, instead of fixing the race car I changed the crank seals on the chainsaw, because wood burner Some damn tight (and lock tighted) m6 head bolts Who knew plastic crank cases were a thing! Quick tip, don't trust the youtube videos that say you can pull the old seals out with the head on in a husky 440e...not true, their crank seal tucks in behind the cover both sides. I'm not sure I'm a psychopath, but these things are damn loud....hope I can put all the bits back in the right place    Happily, it is now back to turning fallen trees into a combination of firewood logs and wood chips....just need a clear day to get into it properly
    • I've got 60L of e85 in there at the moment
    • Don't forget to make sure the tank is full to the brim before you try to replace the fuel pump too, that is an essential step.
    • No, 260RS/4wd stagea is 33 GTR/GTS4 double wishbone all round, not struts. The 2wd cars are confusingly strut front. At there rear there is one balljoint at the outer end of the lower control arm. If you have HICAS (my Stagea doesn't, but I think 260RS did, there will be a balljoint of sorts where the HICAS arm attaches to the rear of the hub At the front, there are ball joints either end of the lower control arm, plus the tie rod end for the steering arm
