Have been looking at M35 info. Is there a twin turbo model available and is it able to be complied?
Nope. The only turbo model was from 2001-2004 and is the VQ25det.
Feel free to get one and add another turbo if you wish though :rolleyes:
There is one advertised in carsales in Qld. A dealer, says "Twin Turbo". Check it out.
Sorry Hugh.
Just a standard RS with the factory Aero kit and a Dolphin grill.
Considering all the piping is stock, there is no way he could be running an additional turbo in there.
Edited by iamhe77
maybe you should make an offer and then ask where the 2nd turbo is? Make them install it.... it would really go then
Please excuse me if this has been posted elsewhere but I couldn't see it.
I was talking with Northshore Prestige yesterday and they said they've now got approval for compliance of the VQ35DE engine (and that they were the first and only at the moment). Evidently there's a 2006 Stagea that should be available in a couple of weeks (it's been to the Ford factory in Geelong for testing) and quite a few more on the way.
He seemed to think it'd be priced at about $28-$29K.
No it has not been posted and you are correct.
Keep an eye on their web page next week.
yes it is, it doesnt appear to be installed on any other nissan engine that we can tell...........
$28-29k?? thats not unreasonable! thats very tempting to upgrade if i could get enough of a trade in for my car. which i probably wouldnt :action-smiley-069:
$28-29k?? thats not unreasonable! thats very tempting to upgrade if i could get enough of a trade in for my car. which i probably wouldnt :)
The import duty drops from 10% to 5% in 2010 that might equate to about a $1-$2K saving on a $30K+ car. So it'd be worth holding back until that saving takes effect. Though this may mean your car is worth less as well...
Its all swings and roundabouts and the value of the yen/$A/$US
and the fact that japan know what cars go where and adjust the price according ling. japanese economy also has a bit of bearing on it.
I've read quite a few posts about the limited life of the stock turbo. I was just wondering if this is specific to the M35 or not?
The turbo itself is specific to the M35, the turbo problems are not. I believe the issues are exactly the same as with earlier model stageas, however the M35 runs more boost as standard, particularly the ARX (going by the posts above or on prev page), making a turbo failure far more likely on the M35 than previous stageas.
The turbo uses a ceramic turbine which tends to come unstuck from the shaft or shatter when it is exposed to a certain amount of heat for a certain amount of time. If you search all over these forums (skyline R33 & R34 have same issue) you'll find that its generally agreed that 14psi is pretty much the limit for these turbos. more pressure means more heat and if you run 14 or higher psi for any length of time, sooner or later the turbo will break. Why Nissan released the car from the factory running such high boost on these turbos will probably remain a mystery. It seems they were aware of it because the turbo is apparently supposed to be replaced at 100,000km.
My RS is stock and runs around 11-12psi which by rights should be fine (my turbo is still going very well at 108,000km) but the bottom line is that if you buy an M35, bear in mind that the turbo may need replacing at some point. It should cost under $2K to replace it with something similar to the factory one, and from there it will likely never need replacing again.
Thanks for the info.
So if I end up with a Series I or II then the turbo may still be an issue (as per any any other parts of the car) but it is less likely as the boost has been running lower over it's life time (provided the owner hasn't increased it).
I'm sorry to say this but, I would think that a fair proportion of them out there have had the boost raised, even if the owner denies it! :D
I an really trying to like the M35, but that arse end is so ugly. If someone was to make adecent rear lights kit, like was done for Commonwhores, I may be tempted. Front and side, AOK, but...........
I have bBenny,s pic as my desktop.
Nissan made the arse end like that just to keep the cops off my back. Works a treat, even with a 3 inch straight through exhaust.
Just gotta get some Volvo badges for the back and I will be in the clear.
You could always paint the top part of the lights to match the car...
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
