  • 3 weeks later...
Sweet. Hoping to pick up the car tomorrow after work :(
Thanks Iain. Looking forward to owning and driving the M35.
I can't believe their a 2002 model. They look so modern.
What's the go with the flutter on this video? Is this just because that part of the intake pipe was removed?
nah thats the examination panel for the air filter. just a cover on it sits there loosely.
and in answer to your other question ..definately not..thats a aftermarket bov on that thing... no turbo flutter on my vq although i wouldnt mind it ;D
Also done some reading up on the NM35's (neo based autos) and they do have a similar setup driveline wise to a GTR ,
A site mentioned something to this effect ..
1. sports mode - puts enough traction to the front to stop the rear from losing traction (80-20~)
2. syncro mode - 50-50 equally front and rear percentage
3. snow mode - hydrolic/hicas sensitive for launch control so theres no wheel spin (even with your foot flat wont deliver power to rear diff until youve taken off).
hope that helps
Edited by PetroDola
You're welcome dude.
I'm pretty new to them also.. i've owned mine a week now.
Although Ive been wanting one for 4-5 years prior but could never afford it until recently.
its by far the best car purchase ive ever made ;)
that is flutter, lol. and the reason they uploaded the video with the examination panel off - makes it more audible
Non standard BOV creates the flutter.... but be warned it is a sure way to attract the attention of the police and nice little fine.
Is that state specific ?
Like i see alot of r32's,33's 180's 200's, and s15's around with aftermarket bov's that are clearly audible in QLD.
Do the same rules apply across aus ?
  • 1 month later...
  • 4 weeks later...
Andy,
Do you know where you can buy the power duct from? I assume the price you quoted is from Nissan spare parts with which part number?
It is the same air box as used on the V35 that has a "power duct" fitted in this spot for the NA motor.
Many M35 owners have opened this spot up. Some have been to Nissan for the "power duct" ($180) and other have made their own way of sealing the box from hot air from the motor.
Just had a look, and I'm looking for the top part (not the bottom part as shown) that has the extra opening at the front (where the "inspection hole" usually sits)
The M35 3.5 litre stageas have this extra snorkel there.
Just had a look, and I'm looking for the one that has the extra opening at the front (where the "inspection hole" usually sits)
You wouldnt have happened to see any pics of these would you? Ive never noticed anyones air filter looking remarkably different to what Ive got in mine (Even though Ive heard people go on about these 'power ducts'). A visual comparison may be in order ;)
Yes, but does anyone know where to get said vent? ;)
Would it actually add any additional air flow? Im sure you could pull a nissan part number for it from FAST if you were after it, but it just looks to be a beveled edge on the inspection hole :)
Nissan Aus. around the $180 mark :)
But it is no cheaper from the US!
Would it actually add any additional air flow? Im sure you could pull a nissan part number for it from FAST if you were after it, but it just looks to be a beveled edge on the inspection hole :P
yes, more COLD airflow
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
