  • 3 weeks later...
Sweet. Hoping to pick up the car tomorrow after work :(
Thanks Iain. Looking forward to owning and driving the M35.
I can't believe their a 2002 model. They look so modern.
What's the go with the flutter on this video? Is this just because that part of the intake pipe was removed?
nah thats the examination panel for the air filter. just a cover on it sits there loosely.
and in answer to your other question ..definately not..thats a aftermarket bov on that thing... no turbo flutter on my vq although i wouldnt mind it ;D
Also done some reading up on the NM35's (neo based autos) and they do have a similar setup driveline wise to a GTR ,
A site mentioned something to this effect ..
1. sports mode - puts enough traction to the front to stop the rear from losing traction (80-20~)
2. syncro mode - 50-50 equally front and rear percentage
3. snow mode - hydrolic/hicas sensitive for launch control so theres no wheel spin (even with your foot flat wont deliver power to rear diff until youve taken off).
hope that helps
Edited by PetroDola
You're welcome dude.
I'm pretty new to them also.. i've owned mine a week now.
Although Ive been wanting one for 4-5 years prior but could never afford it until recently.
its by far the best car purchase ive ever made ;)
that is flutter, lol. and the reason they uploaded the video with the examination panel off - makes it more audible
Non standard BOV creates the flutter.... but be warned it is a sure way to attract the attention of the police and nice little fine.
Is that state specific ?
Like i see alot of r32's,33's 180's 200's, and s15's around with aftermarket bov's that are clearly audible in QLD.
Do the same rules apply across aus ?
  • 1 month later...
  • 4 weeks later...
Andy,
Do you know where you can buy the power duct from? I assume the price you quoted is from Nissan spare parts with which part number?
It is the same air box as used on the V35 that has a "power duct" fitted in this spot for the NA motor.
Many M35 owners have opened this spot up. Some have been to Nissan for the "power duct" ($180) and other have made their own way of sealing the box from hot air from the motor.
Just had a look, and I'm looking for the top part (not the bottom part as shown) that has the extra opening at the front (where the "inspection hole" usually sits)
The M35 3.5 litre stageas have this extra snorkel there.
Just had a look, and I'm looking for the one that has the extra opening at the front (where the "inspection hole" usually sits)
You wouldnt have happened to see any pics of these would you? Ive never noticed anyones air filter looking remarkably different to what Ive got in mine (Even though Ive heard people go on about these 'power ducts'). A visual comparison may be in order ;)
Yes, but does anyone know where to get said vent? ;)
Would it actually add any additional air flow? Im sure you could pull a nissan part number for it from FAST if you were after it, but it just looks to be a beveled edge on the inspection hole :)
Nissan Aus. around the $180 mark :)
But it is no cheaper from the US!
Would it actually add any additional air flow? Im sure you could pull a nissan part number for it from FAST if you were after it, but it just looks to be a beveled edge on the inspection hole :P
yes, more COLD airflow
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
    • Most driving should* be done on one side of single lane divided roads. In the RHD world, you drive on the left side of the dividing line and the road is probably cambered equally on both sides. So your side of the road slopes away to the left. The same is true for the LHD world, just everything swapped to the other side and opposite slope. With a perfectly neutral, straight ahead wheel alignment designed to drive straight on a perfectly flat surface (or at least one that is level on the left-right axis, even if it has some slope in the fore-aft axis) you will not be able to drive on a cambered road without the car wanting to drift down the camber. You will need to add steering input in the opposite direction all the time. This is annoying. The solution has always been to set the camber and/or the caster to produce a continuous turning force in the opposite direction of the camber. The car will drive straight on the kind of camber for which it was set up, presumably as described in the top paragraph. But.... when the car is set up this way, as soon as you get into a lane, usually on a multi-lane surface road or highway, where the camber is not as presumed during setup, the car will usually pull to one side. In the RHD world, if you are in the fast lane on a big divided road, you are probably on the opposite camber compared to what the car was set up for (ie, sloping down to the right) and the combination of the setup and that camber will make the car want to go right pretty hard. Even a perfectly flat lane will tend to want to go right. There's no getting around it. Civil engineers who know their stuff (which is not an assumption that can always be made) will attempt to keep the variation in camber across a multi-lane road as small as possible, and if they can will attempt to make the fast lane as close to flat, or even cambered in the same direction as all the other lanes. This takes a lot of planning for drainage, control of levels, ability to deal with the elevation changes that occur at road junctions, etc etc. So it's not trivial to get it right. When they do make it work, then the annoyance is reduced, along with tyre wear, fuel consumption, etc. In theory, the civil engineers are supposed to worry about those aspects of road design also. * This used to be true, but now with very large highway systems, even just multi-lane surface roads running everywhere, it is less true now than it was, but the old assumption is the basis for describing the phenomenon, so let's just run with it for the moment.
    • I think the consensus was that's normal. Sloped road surfaces or something? I remember @silviaz went through this before. It might be one of those things you never notice until you pay attention to it.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
