there are a few options to be able to do burnouts
1. sell your stagea and get a commodore
2. grow up and dont try to do burnouts in car designed for AWD
+1
commodores are not my friend, chocolate is!
I'm too old to grow up, and I am quite iresponsible
My car is RWD
oh and I'm a drifter, D1NZ
LOL @ discipline fail
Haha
So is there any use asking for tech help on this forum. or is this an anti-fun forum.
Plans are to do suspension, shocks and springs, swaybars, nolathane bushes and brakes.
What I want is the car to be able to do a skid if I want to, it will not be a drifter, I have a race car or two for that, it's my daily after my C34 tow car got worn out.
Me at a Drift Demo
Me at our local track, practice
Not anti fun at all, most of us love skids. But skids and speed off the streets. Most of us live in areas that imports are pretty heavily targeted by the authorities, and as a community we want to promote off street activities. Search YouTube for some SAU texi vids for and example.
So when you just ask how to do skids, don't be suprised by the response! Most people reserve skids for kids with flat caps in commos.
So, to the car. If you bought a 2.5 or 3.0 and trying to do skids, your a derp. If you bought a 3.5 then you have some options. You can go down the NA bolt on route. Exhaust, plenum spacer, z tube, maybe a tune if your rich. That might get you to skidville. Other options are turbo or supercharger kits.
Best thing you could really do with a rwd, is a manual conversion. Just do it from a manual v35 wreck. Skids would be much easier, and more fun to drive.
Don't worry about the brake wire cut, in NA cars it doesn't exist.
Cheers Stagea Cuz.
Off the 'skids' topic for a sec, does anyone have any advice on the most appropriate place to fit a sender for a transmission temp gauge?
Looking at the box, theres two possibilities I could see:
One at the back just above the sump
And another on the side near the lines to the radiator, but it might be a bit close to the front propshaft depending on how big the sender is
Anyone fit one before that could tell me which is the best spot?
I'm just doing an inline one, brass bspt barbed air fittings for the trans hose and 1/8 bspt for the sender thread. I only plan to monitor the trans temps, but the other inline sender for the new -12 engine oil cooler lines will control the thermo fan. (its mounted right behind the engine oil cooler.) I will get some pics when I re-install the engine.
I think I've seen them mounted in the side of the pan. Can't quite picture the locations you've supplied, but I'd be wary because the valve body sits pretty snug in there. Better of in the pan of fluid I would have thought.
That would be my choice; weld or braze a bung in to the pan.
The other thing; I wouldn't be surprised to find a spring & detent ball behind one of those bolts...
Edited by Daleo
Haha
Welcome Darren. Nice vids btw.
Don't worry, you'll get plenty of tech help here (& on itsnotavolvo.com.au) & a small amount of ribbing occassionally, as you've seen. It's all in fun & (mostly) everyone on here are good blokes with heaps of knowledge between them. Being mainly family guys &, ermm, responsible types, you will never hardly ever hear us talk about driving illegally. It's what sets us apart from the others :)
the only worry i have about the sender sitting on the side of the pan is ground clearance - my car is stupidly low at the moment :/
last thing i want is the sender getting torn out while my wife negotiates an Everest sized speed hump & leaving a trail of gearbox fluid all over the street where it doesnt belong...
If you're worried about that; you (I) could roll a piece of sheet steel as a shield around the underside of the bung & sensor & weld on to the pan.
I don't think it would be an issue TBH; Jetwreck would be able to tell you if he's ever seen a pan with gouges or dents, mine didn't even have a stone chip in the paint.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
